Safe & Adjustable Weigh Safe Hitch Upgrades at CARiD I Buy 1 - Get a Gift!
Old Feb 12, 2025 | 12:20 PM
carid's Avatar
Vendor
If you’re looking to enhance your towing experience or need a reliable trailer hitch and ball mount to tow trailers of varying heights, you’ve come to the right place! CARiD proudly presents the top-3 ball mount applications by Weigh Safe.
Weigh Safe is a world-renowned manufacturer of premium-grade ball mounts, featuring a built-in scale that measures tongue weight. This innovative design helps you achieve the perfect towing balance, improves trailer stability, and provides real-time tongue weight readings at a glance, ensuring a safer and smoother ride.
Today, Weigh Safe ball mounts are considered essential for safe and hassle-free towing. No matter what size, length, drop/rise, class, or ball size you need, including pins and clips, Weigh Safe has you covered. Let’s take a closer look at the following top-rated applications:
Weigh Safe® - Class 5 Adjustable Ball Mount with Built-in Scale for 2-1/2" Receivers
[/url]
Engineered for heavy-duty towing, this powerhouse supports up to 18,500 lbs, making it the ultimate choice for demanding hauls.
Specifications:
  • Gross Trailer Weight(GTW): 8000 lb and 18500 lb
  • Receiver Tube Size: 2-1/2"
  • Diameter *****: 2" and 2-5/16"
Weigh Safe® - Class 4 180 Hitch Adjustable Dual Ball Mount for 2" Receivers
Combining versatility and strength, this mount features an impressive 12,500 lb max GTW, perfect for a wide range of towing needs.
Specifications:
  • Gross Trailer Weight(GTW): 8000 lb and 12500 lb
  • Receiver Tube Size: 2"
Weigh Safe® - Class 5 Adjustable Ball Mount with Built-in Scale for 3" Receivers
Built for extreme towing jobs, this rugged hitch boasts a staggering 21,000 lb max capacity, making it the go-to choice for the toughest hauls.
Specifications:
  • Gross Trailer Weight(GTW): 8000 lb and 21000 lb
  • Receiver Tube Size: 3"
If you're ready to upgrade your towing setup with precision, durability, and industry-leading technology, Weigh Safe® ball mounts are exactly what you’ve been waiting for.
Old Feb 12, 2025 | 12:26 PM
carid's Avatar
Vendor
Take Advantage of our Exclusive Offer!
Whether you're towing a heavy-duty trailer, a loaded car hauler, or a work rig, one thing is certain: tongue weight matters. That’s where Weigh Safe revolutionizes towing safety.
Now for the exciting part!
Purchase any of the Weigh Safe Adjustable Ball Mounts with Built-in Scales mentioned above, and you’ll receive a FREE product of your choice from the options below:
  • Trailer Coupler
  • Ball Lock
  • Hitch Storage Case (WS23) & 3-Piece Lock Set
Don’t miss your chance to create the ultimate towing setup—adjust your trailer height in seconds and get a FREE bonus with your purchase!
91rangerturbo
Sep 11, 2008 08:38 AM
12valve@heart
Jun 19, 2007 10:54 PM
4x4not
Sep 15, 2005 09:30 PM
Ripper406
Sep 11, 2005 07:59 PM
Dave88LX
Jul 24, 2005 10:45 PM
