Track Pic Of Blown Plug- Rather Unique
Old Oct 2, 2006 | 05:55 PM
RamWheelsBy4's Avatar
Originally Posted by lmills
yeh the combination of the headgasket leaking slightly from increased cylinder pressures combined with the speed of the water pump cirulating water pressurizes the system enough till "POP".
Well I hope the studs will eliminate any head gasket leaking and I guess that I will just have to run a little less over fueling until I get the rest of the mods(cam, springs, injectors, modded cp3 and twins).
Old Oct 2, 2006 | 10:45 PM
Clint S.'s Avatar
I did some Photoshop work on the photo to make things a bit more visible:
Old Oct 2, 2006 | 10:53 PM
Thanks, my ps computer was not available when I got the email or I would have tried to lighten it up a bit. Email resolution is not much to work with. Still it is a good shot, that is the 1/8 mile trigger and I was a little over 86mph at that point.
Old Oct 3, 2006 | 12:11 PM
Luken's Avatar
That was going to be another great run. I just found a 12.65 time slip and I was only going 85.47. That smarty sure is working good on your truck!
Old Oct 3, 2006 | 12:15 PM
haloman's Avatar
Maybe someone could p-shop out the smoke and plug. Still a very neat pic though.
Old Oct 3, 2006 | 12:20 PM
Sense I really did not know it happened until I slowed down it turned into a 12.81s @ 106 slip. I will be backing off the stack settings for a while to find a consistent dial in time. Probably look for 12.9x stack with moderate 15psi launches for the DHRA even in couple weeks.
Old Oct 3, 2006 | 12:54 PM
Luken's Avatar
I wish I could make it down there...
Old Oct 3, 2006 | 01:09 PM
Sloverado's Avatar
I am trying to make it down there. I went to Shieds the end of Augest and it was great. If I can get a couple of buddies to go down I will be there.
Mexstan
Oct 14, 2006 12:51 PM
crobtex
Oct 8, 2006 10:31 PM
Bad Ramer Jamer
Sep 4, 2006 03:15 PM
janb
Jul 5, 2005 07:03 AM
Shovelhead
Feb 13, 2004 03:50 PM
