Those pulling with autos, need input
Old Sep 27, 2009 | 04:14 PM
sqrl$$'s Avatar
I am probably going to pull for the first time on the 10th. I have a Georend Billet tranny with a lock up switch. Does anybody pull using the converter locked up? Will this break stuff, help or hurt?
Old Sep 27, 2009 | 08:16 PM
silverram323's Avatar
I also have a goerend trans with a lock up switch. When i pull i put it in drive, lock out OD, leave converter switched unlocked. Once im in 3rd gear 4x4 low i flip the tq switch so its locked up and run it all the way to about the last 10 ft. then un lock and lift lightly.
Old Sep 29, 2009 | 09:09 PM
kruegerlouie's Avatar
also run a georend trans. od locked out,dave told me to run as this:after truck shifts into 2nd lock the TC and I leave it locked till truck starts to pull hard tward end of pull then unlock it. running my truck this way for 2 seasons now.
Old Sep 29, 2009 | 09:14 PM
Dave makes one sweet tranny huh...
Old Sep 30, 2009 | 07:55 AM
sure does. mine never even unlocks the converter untill I let off. It will let it lug. only time it inlocked it lugged hard cause it hit od. silverram323 does yours unlock as soon as you hit the switch??
Old Sep 30, 2009 | 08:22 AM
I have mine on a 3 way switch. I have auto setting (computer controlled) unlocked and locked. when i lock mine up it will stay lock until i flip the switch, i also have the VB set so it will not down shift for the dyno. As soon as i hit the unlock it does instantly.
Old Sep 30, 2009 | 09:33 PM
Stovetop535's Avatar
Dont mean to stear this thread off topic but....you guys with the lockup switches, are they the one I have seen on this webpage, the diy lockup where you splice into the wires?
Old Oct 1, 2009 | 07:44 AM
Originally Posted by Stovetop535
Are they the one I have seen on this webpage, the diy lockup where you splice into the wires?
Link? yes i cut the wires
Old Oct 1, 2009 | 10:10 AM
Link from DTR
https://www.dieseltruckresource.com/...=lockup+switch
or this one from cumminsforum
http://www.cumminsforum.com/forum/3r...rks-great.html
I have been thinking about doing this, but I would much rather have it set up so the computer does it rather than myself manually.
Old Oct 1, 2009 | 10:22 AM
BigErksG2's Avatar
I'm not a puller but wouldnt it be better to lock it up manually and then let the computer unlock it once the wheel speed gets to the point it automatically unlocks? Or is there a benifit of unlocking it early?
Old Oct 1, 2009 | 10:30 AM
Wow, that is a good write up. All i did was cut my orange and black wire and run it to the cab. add a ground and wired it to a 3 way switch far right is auto, center is unlocked, and far left locked. all you have to do is connect the wires back together for the auto through a switch. do nothing for the center-unlocked and then add a ground to the locked up side. make since?
Old Oct 1, 2009 | 10:41 AM
Yeah that makes since.
SMOKE' EM
Feb 10, 2007 12:08 PM
dodgeboy59td
Competition / Pulls / OffRoad
Aug 28, 2006 12:54 PM
LanceD
Oct 15, 2004 01:12 PM
crankbait
Jan 16, 2004 12:25 PM
st_pinetree
Apr 13, 2003 07:59 AM
