Osgood IN.
Diesel Pick Up Truck Pull
Rules And Classes
Sat. July 29, 2007
Note: Inspections Are Required- No Trucks Will Race That Have Not Been Inspected.
Gates Open 4:30 - Inspections Close Promptly At 7pm, No Exceptions!
All Late Entries Will Be Turned Away!
Classes
8000 Lb Max Diesel Factory Stock
Street Tires Only 285 Or 33-12.50 Limit - Blows Excessive Smoke Will Be Dq’ed
No Gauges, Weight Brackets, Ladder Bars, Block Suspensions, Chips Or Programmers
No Propane/nitrous Oxide - Must Have Factory Air Box/exhaust – Add Weight In Bed Only
8000 Lb Max Diesel Super Street
Street Tires Only 285 Or 33-12.50 Limit- No Aftermarket Turbos – Airbox/exhaust Ok
No Weight Brackets, Ladder Bars, Block Suspensions, Propane/nitrous Oxide
Gauges Allowed – Chips And Programmers Allowed – Add Weight In Bed Only
8000 Lb Max Diesel Modified Street
Street Tires Only 285 Or 33-12.50 Limit- Aftermarket Turbos Ok – Airbox/exhaust Ok
Weight Brackets Ok - Ladder Bars Ok - Block Suspensions Ok – No Propane/nitrous
Oxide Or Water Injection- Gauges Allowed – Chips And Programmers Allowed
8000 Lb Max Diesel Modified – Not Street Legal
Open Class – Anything Goes Unless Deemed Unsafe By Inspectors-
Call Ahead For Questions Before You Get There And Can’t Run!!!!!
8000 Lb Max Open Diesel Street – Nitrous Oxide, Etc
26" Maximum Hitch Height
Factory Stock And Super Street Must Pull Off Of Reese Hitch Or Factory Bumper
Rules And Classes
Sat. July 29, 2007
Classes
stay away ! stay far away! One of the worst pulls i ever have been to ever! Tech is horse **** there, if its not a dmax they try to there damnedests to make up excuse why u cant pull in the so called class
I'm going to try to be there, not sure though. Its not a real Big pull, the fair grounds is not very big eather.. But they somehow get a half way turn out compared to the other local fairs... Haven't talked to Jamie yet, but i'm sure the HPD guy's will be there!!-Chris
pull
Yes Im sure all the HPD guys will be there. Jamie, Jesse, Doug, and Joe..... and if I get my new HRVP on the truck Il be there. Last year they let the tracy moore pull with the guys with either ladder bars or any aftermarket single turbo. My buddy had just started to build his dmax truck and only ladder bars on ( everything else was on order) his truck and he was in that class... horse****..... I would like to see some of these county fair allow the stock turbo class to have weights in the front. I see a lot of the trucks in this class are farm trucks and they all reg cab truck!!! What do you guys think???
