Florida Pull Info
Old Sep 2, 2007 | 05:21 PM
TNRGreene's Avatar
Florida Pull Info
When: September 15th, 2007 starting at 5 pm.
Where: Charlotte County Fair Grounds 2333 El Jobean Rd.
Directions: I-75 to exit 179 then south on Toledo Blade across u.s. 41 then right on El Jobean Rd also(s.r. 776) until you see the fair grounds.
Pulls start @ 5:00 p.m., weigh-in at 3:00. This will be a regular all pull event.
All diesels will pull in one class regardless of mods. We will seperate the trucks on paper after the event to see who won the stock turbo class.
Try and make it. It's a long track and you need some fairly good speed .
Bring your more agressive tires. 8,000 lb. Hanging weight ok.
Old Sep 5, 2007 | 06:28 PM
MoPower05's Avatar
September 15th is almost here you should know by now if your going to be there. This is a good track to try for the first time. There isnt much traction so those of you that are afraid of hurting your daily driver this track is for you. Whos coming?
MoPower05
Competition / Pulls / OffRoad
Apr 17, 2008 11:31 AM
MoPower05
Aug 22, 2007 11:22 PM
03dodgeoffroad1
Jul 23, 2007 05:26 AM
TNRGreene
31
Jun 21, 2007 09:12 PM
