Did yall know...
trust me its fun...but only do it if you have a good DD clutch
My truck is all stock, save for the BHAF and the exhaust, and Im scared to do any kind of launch. Just waiting on the day when I launch it and see the transmission guts laying on the pavement in the rearview...
getblown, you only 20 psi on a 3rd gear launch? by the time i start rolling (or when the tires break loose
) im hitting AT LEAST 35 psi.
same size compressor but my B1 is larger on the exhaust side, and spools a little slower than a SPS or PS62
As long as your in 2wd and your tires are spinning you will probably be OK
Its in 4wd and you actually hook the power to the ground that your shafts wont be happy, you might also want to be careful doing lock-up shifts into OD as you will have good hook there and that shift can take out a shaft with the right VB
