Best Year For 800 To 1000 Rwhp
Old Feb 3, 2006 | 09:11 AM
HOHN's Avatar
Don't count out yet the HPCR guys.
They'll figure out a way to give the common rail some VOLUME, and when they do, no one will remember the 12V.
Old Feb 3, 2006 | 10:00 AM
cumminsdriver635's Avatar
Those are fighting words it is going to be a WHILE before the HPCR's or anything else will even come close to a 12 valve. You can just get so much fuel out of the P style pumps that its rediculous. Plus; they wont turn the RPM's yet either. The 12 vave will NOT be forgotten
Eric
Old Feb 3, 2006 | 10:25 AM
Don M's Avatar
DTR Advertiser
How prophetic that is.
Old Feb 3, 2006 | 11:52 AM
mcoleman's Avatar
I agree with Don. I don't see the rpms or the fuel being a problem much longer for a common rail at all.
Old Feb 3, 2006 | 12:21 PM
MikeyB's Avatar
Well lookie here.....
http://www.turbodieselregister.com/f...d.php?t=150141
MikeyB
Old Feb 3, 2006 | 01:29 PM
KLockliear's Avatar
It doesn't take 800rwhp to go 12.50's. If that's your goal, it's relatively easy to do these days. With a good auto trans, should take around 600-650hp assuming your truck is not grossly overweight.
Old Feb 5, 2006 | 08:29 AM
DART505's Avatar
[B][I]It's grossely overweight truck & driver 8340# I am trying to get all the horsepower I can & still drive it every day! Right now I am trying to get some more air in it.I had a single GT42r on it with 102mm compressor wheel , got rid of it & working on a twin setup right now to get the 1900 degree+ EGT's down but won't have a inner cooler.You Cummins guys have it so easy! you go out & buy a kit not so with the 7.3's unless you want a 550 hp one.I am hoping that I can make close to 700RWHP without blowing the main saddles out of the block,wish I would have known about the availability of main girdles when the motor was out!
Old Feb 5, 2006 | 09:24 AM
John_P's Avatar
DART505:
I wanted to let you know that a friend of mine (Mike Reaves) just had Scheid Diesel completely rebuild the 7.3 engine in his 2001 Ford PSD including the install of Scheid's Twin Turbo's for that truck. They did other performance modifications to the lower end but I can't remember everything they did. You can give J.P. (John Pezan) a call at Scheid Diesel (Terre Haute, Ind.) @ 1-800-669-1593 if you want more information on what they did to Mike's truck.
Hope this helps you out some.
John_P
Old Feb 5, 2006 | 01:20 PM
DART505's Avatar
I knew that they had toasted a few 7.3's at Scheid because of lower block weakness.There is no question that they can make some power there.I am convinced that the 7.3 can put so much fuel in that if you put enough air in there the block can't hold that much power.If I would have done this motor from start knowing what I know now I would grout the bottom of the block to the bottom of the freeze plugs & put a girdle on the mains & port the heads.
Old Feb 5, 2006 | 04:00 PM
John_P's Avatar
DART:
Yes, I believe you are right. They did have some early problems with Mike's first engine with the issues you had mentioned. However, I think they got all of that taken care of and this most recent engine is doing well for him.
John_P
Old Feb 5, 2006 | 05:42 PM
DART505's Avatar
I would like to know what they are doing being this is mostly uncharted terratory except the dedicated guys that are all custom throwing money at it like mardigras beads Throw me sumthin mista!
Old Feb 5, 2006 | 09:40 PM
John_P's Avatar
DART:
Give J.P. a call up there if have time this week. I know he can give you a run down on what they did. Tell him I gave you his number if you want. We are good friends.
Take care.
John_P
Old May 3, 2006 | 01:05 PM
DART505's Avatar
John,I called JP last Tuesday & I still did not here back from him so I called again & left a message to call me back.Thanks! Chris Pitre
got some new pics of my contraption.
Old May 3, 2006 | 09:07 PM
John_P's Avatar
Chris:
I talk to J.P. pretty regularly, so I will let him know you are trying to get a hold of him. I should talk to him tomorrow.
John_P
Old May 4, 2006 | 01:50 AM
WUnderwood's Avatar
Dart505-
this is redrocket from TDS; I am converting to 'The Dark Side', and buying a Common Rail Dodge, and I hope to be in the 12's shortly. I am tired of pouring $ into the Ford, when the Dodges are doing it SO much easier
flame suit on
