anyone use a motorhome to pull their truck?
Old Aug 31, 2008 | 12:45 PM
morkable's Avatar
If so what are you using, how does it pull, what would you change if you could
thanks
Kevin
Old Aug 31, 2008 | 02:00 PM
DieselLady's Avatar
98 Newmar Mountainaire 40 feet 8.3 cummins 12 valve. Twin Turboed Hot rod P pump. Pulls like mad. Easily does 80 on flat and will climb at 55 with little effort. Make sure you have good brakes. EGT and boost gauges are critical as the coach was pushing 1600 degrees sustained before the added air flow. Now it rarely exceeds 1250.
Shorts
Jun 22, 2011 12:51 AM
dodgetrucker75
Sep 21, 2009 12:52 PM
greasy
Cummins Conversions
Sep 12, 2008 09:59 PM
06Cummins
Feb 16, 2006 05:31 AM
hotdram
Dec 10, 2004 08:52 PM
