2007 Truck pulls in IN, KY & OH
good pull in west union last nite, glad to get to see more than just 1 pro truck run, it was Kurt Haisley, Erik Stacey, Jeremy Straley, and Terry Martin in the po class. i spent about 30 minutes talking to Patty Haisley last nite and got some good ideas for our big pull in hillsboro. hopefully we will have 150+ trucks there this year, we are having Singers green and white sled. KENNY BALL WILL NOT BE RUNNING HIS SLED THIS YEAR, there was alot of problems with him last year and he is out. we got a great track, great facilities and a great sled.
what pulls are in southern indiana this weekend?
Vanderburgh County Fair Evansville, IN July 26 6pm...
http://www.vanderburghcountyfair.com/schedule.asp
Its going to be awesome!!
friday nite at the fayette county fairgrounds in washington court house ohio, here are the rules:
Street Legal Diesel Pickups Purse: 300, 250, 200, 150, 100, 75, 50
Street Legal 2007
1. ALL TRUCKS WHO PLACE IN THE MONEY WILL BE TECHED!
2. 8000 lb Dual Rear Wheels Allowed
3. No Nitrous, Propane, Alcohol, etc. #2 Diesel Only
4. No Water Injection
5. Hanging weights allowed, furthest point must not exceed 60” from C/L of front axle
All weights must be secure; disqualification may be enforced if weights fall off.
6. Must have full interior, exterior. Has to remain street legal
7. Must provide license and registration
8. Single Charger only limited to maximum of 2.5” wheel. No reducers, plugs, etc. can be used to make a large wheel charger “fit” into this class. Chargers will be teched.
9. DOT tires, no studs, no cut or sharpened tires.
10. No aftermarket transfer cases or transmissions.
11. Rear suspension must have a minimum of 1” of travel.
12. Must pull from Reese style hitch or factory bumper. Hook point must be at the furthest most point of the vehicle. Hook point must be at least a 3” OD ring or clevis
13. 26” Hitch Height
14. Traction/ Ladder bars allowed
15. Exhaust must exit straight up or straight down- No exceptions.
16. No aftermarket heads
17. Engine must be out of factory 1 ton or smaller pickup
18. Bellhousing blankets required for engine turning over 4200 RPM.
19. Rear U-joint shields required. Driveshaft loops highly recommended
20. For more information call 740 246-6329
21. Track and Tech official’s decisions are FINAL
Pro Stock Diesel Pickups Purse: 400, 300, 200, 150, 100
Pro Stock 2007
1. ALL TRUCKS WHO PLACE IN THE CLASS WILL BE TECHED!
2. 8000lb limit (Dual rear wheels allowed)
3. No Nitrous, Propane, Alcohol allowed. #2 Diesel Only
3. Hanging weights allowed, furthest point must not exceed 60” from C/L of front axle
4. Any single charger and Limited two charger configuration. 3” bore on single chargers- NO PLUGS. Twins must bolt directly to a stock exhaust manifold. The atmosphere charger must have a 3” inducer bore- NO PLUGS. 4/10/2007
5. DOT tires, no studs, no cut or sharpened tires.
6. No aftermarket transfer cases or transmissions i.e. Dropboxes, Reversers
7. Factory rear suspension may be blocked, no custom rigid suspensions allowed.
8. Hitches: Reese style hitch, factory bumper or under bed hitch. Hook point must be 48” from the centerline of the rear axle. Hook point must be at least a 3” OD ring or clevis.
9. 26” Hitch Height
10. Traction/ Ladder bars allowed
11. Exhaust must exit straight up or straight down
12. No aftermarket heads
13. Engine must be out of factory 1 ton or smaller pickup
14. Trucks that place for the payout will be teched (to be determined)
15. Bellhousing blankets required for trucks that do not meet the Street Stock rules
16. Driveshaft loops required for trucks that do not meet the Street Stock rules
17. Water Injection permitted
18. Fire Extinguishers required
19. Injection pump must be stock appearing (for example: No Ag governor on P Pump). Dual CP3 pumps allowed.
20 For more information please call 740 246-6329.
21. Track and Tech official’s decisions are FINAL.
8000 lb RWYB Purse: 500, 400, 300, 200, 100
Run What You Brung (RWYB) 2007
1. 8000 lb
2. Gas or Diesel
3. 4X4 Truck
4. 26” Hitch Height
5. Blow proof bell housing or blanket, kill switch, driveshaft loops, exhaust must exit up or down, helmet.
6. Track and Tech official decisions are FINAL.
6500 Lb. 4x4 Pro Street Gas
Engine
1. 572 Cubic Inch Limit
2. Single Carb or EFI Only
3. Engine Must Be in Stock Location
4. No Blowers, Superchargers or Turbos
5. Exhaust Must Exit Under Truck
6. Open Exhaust Permitted
Fuel
1. Pump Gas or Racing Gas Only
2. No Nitrous or Any Other Pressurized Fuels
3. No Diesels
Drivetrain
1. OEM Axles & Frame, 1-Ton or Less
2. OEM Style Transmissions & Transfer Case, 1 Ton or Less
3. No Rockwells or Quick Change Drop Boxes
4. U-Joint & Driveshaft Protection Required
5. External Kill Switch Required at Rear of Truck
6. Blow-Proof Bellhousings or Blankets Required
Suspension
1. Suspension Must Have Coil or Leaf Springs Front & Rear
2. Suspension May be Blocked
3. Traction Bars Permitted
Tires
1. Tires Must be Street Legal & DOT Approved
2. Tires Not to be Cut, Sharpened or Altered in Any Way
Weights
1. Front Weights Permitted
2. Must Not Exceed 195" of Rear Axle Centerline
3. Total Truck Weight Must Not Exceed 6500 lbs.
Hitch
1. Drawbars Permitted
2. Hitch Must Have 3" Opening at Hook Point
3. Must be a Minimum of 36" Behind Rear Axle Centerline
4. Must Not Exceed 26" Hitch Height
5. Hitch Must be Stationary in All Directions
Body
1. Body and Glass Must be Complete & Meet OEM Specs
2. Must Have Complete Firewall, Dash and Interior
3. Fiberglass Hoods Permitted
4. Beds Must be Complete
5. No Removing of Bed Floor
6. No Aluminum Beds
7. Flatbeds Must be Street Legal & Factory Built or Heavier
8. Must have and Use Seatbelts, Helmets Recommended
9. Passengers Not Permitted
6200 Lb. 4x4 Altered Street Gas
Engine
1. 502 Cubic Inch Limit
2. Single 4150 Carb or Factory EFI Only
5. Exhaust Must Be Behind Cab
6. No Open Headers
Fuel
3. No Diesels
Drivetrain
4. Factory Un-Altered Wheelbase
5. U-Joint & Driveshaft Protection Required
6. External Kill Switch Required at Rear of Truck
7. Blow-Proof Bellhousings or Blankets Required
Suspension
1. Facotry Suspension
2. No Blocks to Solid or Limit Suspension Travel
3. No Welded Shocks
4. Traction Bars Permitted
Tires
Weights
1. No Hanging Weights
2. No Weight Brackets Under Hood
3. All Weight Must be in Bed
4. No Pipe or Homemade Mumpers
5. No Snowplow Frames, Winches or Brush Guards
6. Must Not Exceed 195" of Rear Axle Centerline
7. Total Truck Weight Must Not Exceed 6200 lbs.
Hitch
1. Reese Style Hitch Only
2. No Bars ATtached to Hitch Going Forward
3. No Drawbars Permitted
4. Hook Point Must be a Minumum of 48" From Rear Axle Centerline
5. Must Not Exceed 26" Hitch Height and Be Stationary
6. Hitch Opening Must be 3"
Body
3. Beds Must be Complete
4. No Removing of Bed Floor
5. No Aluminum Beds
6. Flatbeds Must be Factory Built or Heavier
7. Fiberglass Hoods Permitted
8. Tailgate Required if Weights are Not Secure
9. Must have and Use Seatbelts, Helmets Recommended
Street Legal 2007
Pro Stock 2007
9. 26” Hitch Height
1. 8000 lb
2. Gas or Diesel
3. 4X4 Truck
4. 26” Hitch Height
Engine
Fuel
3. No Diesels
Drivetrain
Suspension
Tires
Weights
Hitch
Body
6. No Aluminum Beds
Engine
6. No Open Headers
Fuel
3. No Diesels
Drivetrain
Suspension
3. No Welded Shocks
Tires
Weights
Hitch
Body
5. No Aluminum Beds
whats it matter Wes, your gonna win anyways.
Contact: Jim Stimmel 937-826-3344 for information on Urbana. Xenia is another story, only number i got if for the fairboard office, 937-372-8621, they might be able to tell you or atleast give you someones number that you can call.
