Cat question
Cat question
My C12 Cat has a rubber/foam kinda thing that's wrapped around the oil pan. It's bolted on somehow, (I haven't really looked yet), but it's a 1" thick molded piece, not something that's sprayed on like undercoating.
I'm wondering what the purpose of this thing is and if I can remove it. Somewhere around the oil pan I have an oil leak, (might be the front seal, might be the oil pan gasket), but I can't tell where it's coming from because this wrapper hides the whole oil pan.
It must keep a LOT of heat trapped in the oil pan because when the motor is hot, the oil level 'grows' by 2 or 3 quarts. It goes back down when it cools off, but I've never had a motor like this thing before.
I've said it before and I'll say it again... with this Cat I don't need a mechanic, I need a vet!
That is a noise barrier, it will degrade and fall apart. I am, surprised that it has not already started to come off in chunks. It goes up the side of the block also. You should be able to remove the lower half to inspect for oil leaks, I'm betting on the front cover leaking oil.
Thanks Tim! As always, I appreciate your answer.
I don't remember if I told you or not, but I *think* the fuel in the oil problem has been resolved. We replaced the injector seals and it seems to be ok now. $113 for 18 tiny Rubber O-rings.
Surprisingly simple to do, just a lot of part removing and replacing.I've been carefully monitoring the oil level ever since and have noticed that the oil level will grow substantially when the oil/engine is hot. On the stick it will show the equivalent of an extra 2 quarts when hot, then return to normal when it completely cools down. I've never had anything do that before. I guess it's the 'Cat Learning Curve'!
So I assume I can just remove the whole thing with no negative mechanical effects?
Glad you got the oil fuel dilution solved.
Maybe that rubber wrap keeps in a LOT of heat.
Front gear housing like to leak on C10/12's. The bolts come loose, sometimes go thru the gear train. There is an updated, stronger bolts and higher torque. Also the oil dipstick tube can go in 4 different places on those engines. So the 3 other holes, have a rubber plug installed. They kinda look like a 45gallon drup, but its about 3/4" tall or so. Bet our shop had couple of those engines apart each month for yrs. Then seem to kinda disapper, then boom, 2 in this week for overhauls.
It's not. It's on the right side towards the bell housing. Almost to the side but not close enough to be able to see it when you look up from the bottom of the frame rail. If I had a pit I might be able to wiggle up between the back of the tranny and the next rearward crossmember, between the drive shaft and frame rail and reach forward, but laying under the truck I just don't bend that way anymore!
1969mach1
Mar 4, 2007 06:39 PM
Doubleover
Apr 30, 2006 03:02 PM
