Annoying tic under the hood? I found mine... EASY fix.
Old Dec 1, 2009 | 08:13 AM
madhat's Avatar
Administrator/Jarhead
Mornin, DTR.
I have had this tic tic tic under the hood for a few months now that is constant... I always had one right at start up, but it would always go away within a few seconds.
I've been poking around under the hood, touching injector lines and what not. This morning, I grabbed the #5 line hard and held it, and the tapping stopped. After monkeying with it for a minute, I found that the isolator (blue plastic/rubber with metal on the outside) was loose. When I tightened it up... no more tic!!!!
I made a vid, but you can not hear the tic stop and start.
If someone needs a pic, let me know.
Old Dec 1, 2009 | 10:44 AM
OOPS's Avatar
Yep, common problem!!!!
Old Dec 1, 2009 | 11:27 AM
justin mcfall's Avatar
Great find Mark!!! I will check mine later...
Old Dec 1, 2009 | 11:33 AM
madhat's Avatar
I'm beside myself. My truck sounds like it did when it was new...
Old Dec 1, 2009 | 12:38 PM
michiganracer2's Avatar
Yes, this is a common problem w/ #5. It can even cause fuel to leak, and the smell lasts for weeks.
If you have not checked this on your trucks it needs to be done..
Old Dec 1, 2009 | 12:44 PM
DirtEater's Avatar
Is #5 the 5th one from the front?
Old Dec 1, 2009 | 12:53 PM
madhat's Avatar
Yep.
Old Dec 1, 2009 | 12:54 PM
Yes, I checked all of mine and got a little on all, #5 about a half turn.
I think it was a 8 MM or 10MM wrench I used.
Old Dec 1, 2009 | 01:13 PM
madhat's Avatar
I think it was an 8.
Old Dec 1, 2009 | 01:37 PM
stock03's Avatar
How tight do you tighten the injector if it's loose?
Old Dec 1, 2009 | 02:37 PM
madhat's Avatar
I'm not talking about the injector, just the insulator...
The injector involves a lot more.
Old Dec 1, 2009 | 02:40 PM
stock03's Avatar
Cool. I'll check it out and see if the insulator is the cause of the ticking. Thanks.
Old Dec 1, 2009 | 02:46 PM
madhat's Avatar
Just look at the injector lines, they have a blue and brass part on them. I'll take a pic and load it in a few...
Old Dec 1, 2009 | 02:56 PM
DirtEater's Avatar
Although I haven't checked under the hood yet, a pic would be helpful.
Old Dec 1, 2009 | 03:12 PM
madhat's Avatar
This...
The insulator on the metal line. There is an 8mm bolt on one side, tighten her down, and put a little goo on the back side.
