Al's DIY Spray liner
I just got done using the DIY Al's Liner kit. All I can say is that this stuff works great. It is just as good if not better than the Armorthane liner that Ihave sprayed in my bed. Here are a few shots of the work that I did over the weekend.
Outside of the rockers / Doors
Looks good! I've never used Al's but have heard good things about it. The last batch of liner I tried was Grizzly Grip. Went down well and seems like a good product. The next one will be Al's.
chaikwa.
chaikwa.
Almost everywhere you buy the stuff it will run you $95.00 per 1 gallons worth of material. The gun to spray the material is $55.00. Usually they most all offer free shipping as well. 1 1/2 gallons will do both outsides of the rocker panels, and the inside of the doors as well. To do a full bed with a good coating, you will more than likely need 2 gallons of material.
Here is the final product. The pics are not the best. I had some crud on the lens of the camera
. It has been raining all day, so I could only get the inside shots. The lines are perfectly straight on the truck, even know it doesn't look like it. Bad Pics.
With out the fender flares -
With the flares on -
. It has been raining all day, so I could only get the inside shots. The lines are perfectly straight on the truck, even know it doesn't look like it. Bad Pics.With out the fender flares -
