Twins build GT3782R over a S475
Very interesting considering its Garrett specs that put it at a 61.4x82 mm comp wheel. You can't have a 59.1x82mm wheel with a 56 trim, thats a 52 trim. The stage 2 is supposed to run a 56 trim wheel.
I have heard many different things on the Stage 3 as a single, but the biggest thing is that is likes to surge at lower flow/boost, which doesn't work for my application.
EDIT: Okay I just went and called Tom at Turbo Resource. His data showed 59.1 for Stage 2, but he looked at the literature and agreed that it should be 61.4, so he went and measured one, 61.4x82. So the stage 2 is a 61.4x82mm comp wheel.
stage two is 59.5mm and 0.89, I have one on my truck. Garrett changes stuff, so their is nothing set in stone. The GT37 powerstroke stuff, spins in the opposite direction and is a totally different turbo. I wanted the larger turbine housing for this set-up. This truck will tow and there is no external gate on this build. The 0.99 has a larger internal wastegate flapper, also the S475 will lite harder with the larger GT-37 turbine housing. This is a budget friendly build-up.
Whats the diameters of the wastegates?
Tate, hopefully you remember, that you and I measured both your GT3782R and mine. I originally thought they were 61.5mm, but we measured 59.5mm. The stage 3 has a slightly higher flow 63.5mm 7 blade impeller and the 1&2 have the six blade. I have not measure the exducer of this compressor yet, but have measured the inducer size. I've must have owned four or five of these GT37 now, each time I get one they are slightly different.
I honestly think its a tagging issue on the box. I got a garrett GT3582R and it was in a GT3571R box.
Garrett doesn't spec out the diesel performance line to well. The borg warner stuff is very comparable to the garrett, I just like the quick spool-up of the garrett. The borg warner stuff seems to flexible in its configuration.
Found a decent 68mm inducer mid size frame turbo. There hasn't been to much available until borg warner released its new EFR line.
http://www.full-race.com/store/turbo...180-turbo.html
I want one for my 2010 truck. Should work really well as a single or in twins. Has a built in blow-off valve, for you stick guys. Its 95lbs*min, and would be a wickly sick with a 4718R.
No worries I like talking about turbos alot, I learn something new everyday. Today, I learned that there is a new ceramic turbine wheel become available.
Ceramic turbine wheels are good for heat issues but didnt they have problems with balance, pitting, small debre, shattering, high speed etc? Somewhat fragile. Would really have to have come a long long way to be reliable in big bad diesels.
But maybe they have, Mike?
. I guess that the ceramic turbine don't last long as the inconel. Like you stated they have issues.
Glad to see them twins taking shape. It was worth the drive across the border for this setup. Tweak on!!
I thought the same thing, this is a brand new garrett turbo stage 3, with GT3782R on the box. I measured it up prior to buying. Garrett keeps changing things, suppose to help with turbo stall, which isn't as big of deal in twins. If anything the smaller compressor impeller will help spool-up by reducing rotating mass/interia.
This set-up is going onto a 12V truck with a few tweaks for extra fueling.
Did we decide if the exchanger was moving up front?
Ok guys this is very crude at this point, but courious on what you guys think? Still haven't landed on primary brace exactly. Would you guys want to leave the heat exchanger in the stock position or move it? The air tube is still a work in progress, this is off another project I had laying in the garage.
By the way the turbos are Garrett GT3782Rstage3 over a S475/1.32 T-6.
