Tranny dipstick tube
Old Jul 27, 2009 | 09:04 AM
morkable's Avatar
Hey guys, is there a trick that I am missing here... When I was pulling the AC lines off of the truck I dislodged the dipstick tube, where a large mess insued. I seem to be having a heck of a time to get the sucker to go back in, is there a trick here that I just dont see?
Old Jul 27, 2009 | 06:31 PM
1-5-3-6-2-4's Avatar
its on an oring. no real trick.just has to be lined up just rightnd push down hard to seat it. make sure you don't cut though. and as you found out....the FULL level is above the oring
Old Jul 27, 2009 | 08:06 PM
madhat's Avatar
Administrator/Jarhead
I had the same problem when I put mine back on... I got underneath and pulled, and had someone on the top pushing and wiggling it a little. It's just stubborn.
If that does not work, get a piece of thin rope, tie it around it with about a half inch of play, stick a short socket extension in it and twist it one time to make it tight, then add an extension to either side. Then, pull down on that... it'll give you a little more leverage.
If that was clear as mud, pm me, I'll give you my number, and I'll try to do a little better.
1985cucv
15
Apr 17, 2009 09:06 AM
Dean Snow
Sep 21, 2007 01:18 PM
signature600
Jan 3, 2004 02:24 AM
Jambbii
Nov 24, 2003 11:14 PM
