Quad Boost Fooler?
Old Aug 30, 2009 | 10:14 AM
06RED-BARON's Avatar
Quad Boost Fooler?
Hey i just installed a Quad B/F, and it will not let me go any higher then 24 lbs of boost. I had a boost fooler from ATS that came with my A3000, it was one you splice in line. That one let me hit 32 at times, another thing is my PMT reads zero boost pressure while in town untill i punch it. Its almost like the Quad b/f is fooling my pmt also, i hope this all makes sense. Any idea's
Chad...
Old Aug 30, 2009 | 10:17 AM
morkable's Avatar
yes the boost fooler will fool anything that is after it in line. The only way to properly do boost is with a proper guage. The ones like the PMT that take their readings from the obd port are very inaccurate.
Old Aug 30, 2009 | 10:24 AM
StealthDiesel's Avatar
Chad,
The boost fooler is fooling the ECM. If your BD PMT is reading boost thru the ECM via the OEM MAP sensor, it's readings are now also "fooled".
You may need to install a separate, independant boost gauge.
In my truck, I ignore the boost readings on my Edge Attitude monitor because my Smarty programmer is doing some sort of boost fooling/reprogramming.
I just go by my Autometer boost gauge.
...Joe
Old Aug 30, 2009 | 10:57 AM
I was thinking that was the issue, i deffinatly dont have less power that's for sure. Where in calgary would i find a boost gauge? im in Okotoks for awhile so on a early day i might be able to run in.
Chad..
Kev how's the truck cummin along?
Old Aug 30, 2009 | 02:56 PM
01 Diesel Nut's Avatar
DPS could definitely hook you up with a boost gauge.
Old Aug 30, 2009 | 04:49 PM
im gonna try to get there today, but if not ill try another day. Thanks
Chad...
Mike Holmen's Avatar
The Guru
Mopac sells autometer. They have big selection on hand. I used to have a 40psi ISSPRO, but I gave it away. 40psi is way to small anyways so I gave to my brother duramax
Old Aug 30, 2009 | 05:35 PM
dodgediesel's Avatar
I have a 35 psi Autometer Ultra Silver you can have but I'm in Red Deer..
Old Aug 31, 2009 | 10:21 AM
Serious you dont want anything for it? In that case im working for Helge Scheit right now and herb his brother is coming out tomorrow to pick up some pipe. Maybe you could send it with him? just a thought. That would be sweet. Let me know and thanks a million.
Old Aug 31, 2009 | 11:39 AM
Unfortunately a gauge with 0-35PSI range will not be adequate for a CR Cummins.
You will bury that gauge with any kind of power module/programmer/boost fooler.
A boost gauge with a range to 60PSI will be required.
...Joe
Old Aug 31, 2009 | 12:22 PM
Thats true, i guess i was just over excited with the thought of getting a free one lol. What does one cost brand new usually?? I guess i could do some research and find out.
Old Aug 31, 2009 | 02:11 PM
The Guru
A perfect sized gauge for a duramax or power stroke. My brother didn't use my old gauge as it was too big.
I vote for a 80psi gauge, as it will leave room down the road for mods.
Old Aug 31, 2009 | 02:38 PM
Hey mike i like your thinking, where is mopac located in calgary? I did find some on e-bay for $60 but it would take 2 weeks to get it in my hands. It's hard for me to get anything done while im working cause i dont have a set schedule, sometimes im off at 4pm and other times im off at 9 pm. Ofcourse i allways get a early day on sunday never fails.
Old Aug 31, 2009 | 02:51 PM
morkable's Avatar
130 16th ave NW for Mopac in calgary. The nice thing about getting a new one you get the kit that goes with it including the boost line. Performance parts center is another excellent place to go for parts they are on 32 ave 1695 32 ave to be exact.
Old Aug 31, 2009 | 02:53 PM
No way, Helge!!!! Have his brother Herb call me and it's yours!
