Over sized Pistons ???
Old Mar 11, 2011 | 11:12 AM
roxxx's Avatar
What is the Sizes I can get 10 thou over ? 20 thou Over ?
I am looking at rebuilding one of my motors and was just curious on the over sizes I can Get
Thank you
Old Mar 11, 2011 | 12:26 PM
jtamulonis's Avatar
Thank you
They come .020 and .040 oversize
Old Mar 11, 2011 | 01:22 PM
roxxx's Avatar
Wasnt sure thank you
Old Mar 11, 2011 | 09:02 PM
Mike Holmen's Avatar
The Guru
What ya ordering pistons for? You have the motor apart? Depends on what ya got?
Old Mar 12, 2011 | 09:59 AM
roxxx's Avatar
No Mike the motor Is not apart. I am getting one this week and may be getting a full P-pump motor too
Anyways the 24 valve has burnt back 2 pistons , So i will have to get it honed out, more than likely 20 thou over.
I am not going crazy with the motor so just a standard piston. I want to keep the same compression as Stock .
Old Mar 12, 2011 | 10:34 AM
The Guru
Nice thing is SO VP pistons are priced decently. Mahle has a decent replacement piston. I have 4 standard size VP pistons, if you need them. Just need rings. How bad is the cylinder? Can you clean up the cylinder with a bit of ball honing?
Old Mar 12, 2011 | 11:38 AM
roxxx's Avatar
I think they are beyond a ball hone
I will see what wrong with the 12 valve motor too that may be the motor to go with instead considering it has everything on it still
DodgeRam24V
13
Oct 27, 2011 11:28 PM
dodgetrucker75
Jan 3, 2011 03:01 PM
RollinCoalSmoke
May 29, 2009 09:20 PM
skynyrd
Jan 10, 2008 06:41 AM
ddestruel
May 10, 2005 12:17 AM
