List of Dyno Participants.
Old Feb 29, 2008 | 10:53 AM
  #46
dodgediesel's Avatar
Originally Posted by ramtd02
I counted 10 in this thread alone....plus i think their will be another 5-10 that dont frequent this site.
Nice!!!!
Old Feb 29, 2008 | 10:56 AM
  #47
1-5-3-6-2-4's Avatar
I'll try and wrangle a few other guys to come with me.
Old Feb 29, 2008 | 03:35 PM
  #48
Is your truck gonna be ready???
Old Feb 29, 2008 | 06:45 PM
  #49
morkable's Avatar
welll,, I may be out now,, I am going to change the speed sensor on my tranny and see if that helps,,,, (speedo hasent worked since I blew up the tranny,, ) I only seem to get od every once and awhile,,,, **** thing...... we will see,, I sure hope that fixes it,, Im really pumped about the dyno
Kevin
ps, got another turbo coming,, who is good at building piping???
Old Feb 29, 2008 | 08:06 PM
  #50
Tate's Avatar
You going twins? What do you have coming, S480?
Are you looking at building the piping? Rip at sourceautomotive.biz has all the parts to hook a S400 under a variety of turbos, including your S300.
Old Feb 29, 2008 | 09:06 PM
  #51
It;s looking less and less likely as every day passes..........I do not have the head back yet. or my carp from ceramic coating.......I'm not going to push it back into service too fast. I want good heat cycles and retorques before I feed it heavy boost again.
Old Feb 29, 2008 | 10:07 PM
  #52
Good idea. Don't wanna push out a new headgasket too soon...
Old Feb 29, 2008 | 10:38 PM
  #53
Mike Holmen's Avatar
The Guru
I have a T-88 available for you Kevin. You should have tons of air with that one. How big is your current turbo? I'm not sure of its measurements. The T-88 is almost as big as the big brother and its rated at 1200 to 1400 BHP. The tubing/hot tube shouldn't be to hard to put together. I was planning using the T-88 with the K-31 that I got. Of course I need way more fuel just to get those turbo to start spooling. My tranny feels good so I just have to some tweaking to get the girl to run right. I just picked up a GT-35 series turbo, just doing the old bench spin test, it seems to spools way faster than the 3788 that I have. I have to find a bigger turbine housing as it looks way to tight so anything much more than stock power levels. It might find a home in my car. I'm trying to talk Alamo into coming out to our meet and chat with us. It seems second most popular conversation with us diesel guys is turbo upgrades. #1 is adding more fuel.
Old Feb 29, 2008 | 11:52 PM
  #54
morkable's Avatar
I have a big brother coming,, not totally sure of the complete specs, but I am told it flows fairly equal with a 480 if that makes sense,, it is a big bugger of a turbo,,, I have a silverbullet right now... should flow pretty good with those two together, it is quite a popular combination.... especially with the ammount of fuel that I am running.... I just wish I was a welder,, lol,, Im not even a really good farmer welder,, bubble gum things together
Kevin
oh yeah and I will be ordering my roll bar too this week coming up,,, big things this year I hope
Old Mar 1, 2008 | 12:57 AM
  #55
Kev, if you go with a full cage. Take to to Clay here in Calgary at Evolution. he'll build you a cage like top notch.
Old Mar 1, 2008 | 01:22 AM
  #56
morkable's Avatar
I think that I am just going to go with a roll bar,, dont plan on going much faster
Kevin
Old Mar 1, 2008 | 11:35 AM
  #57
Cummins610's Avatar
What the weight limit for the dyno? I might want to put the 6.7L on but the 5500 is heavvvvy
Old Mar 1, 2008 | 11:39 AM
  #58
Cummins610's Avatar
Actually you probably can't dyno my truck with the 121KM/H limit right?
Old Mar 1, 2008 | 11:47 AM
  #59
weight is probably not a factor so only the rear tires go on the rollers but width is an issue. in my last dyno thread I put down the max width........I don't recall off hand. but all the regular dually 3500s fit on OK with only an inch or two overhang on one side. speed limited I don't think matter either, it will still measure your rear wheel power output up to that point.
Old Mar 1, 2008 | 12:59 PM
  #60
NoSparkplugs's Avatar
Is anyone thats going, gonna have a smarty that I could use to recalibrate my speedometer? It's pretty out of whack with the 37s on (15km/h slow according to GPS) and I'm pretty sure its throwing my shift points outta whack.
