How True Is this ??
Old Feb 27, 2012 | 08:12 PM
roxxx's Avatar
How True Is this ??
TOOL DEFINITIONS:
DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest
and flings your beer across the room, denting the freshly-painted part
which you had carefully set in the corner where nothing could get to
it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere
under the workbench with the speed of light. Also removes fingerprints
and hard-earned calluses from fingers in about the time it takes you
to say, ''What the...''
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their
holes until you die of old age.
SKILL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation
of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor
touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more
dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt
heads. If nothing else is available, they can also be used to transfer
intense welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong the
conduction of intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various
flammable objects in your shop on fire. Also handy for igniting the
grease inside the wheel hub you want the bearing grease out of.
TABLE SAW: A large stationary power tool commonly used to launch wood
projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground
after you have installed your new brake shoes, trapping the jack
handle firmly under the bumper..
EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering an automobile
upward off of a trapped hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters gained from using a 2X4
to try to lift an automobile off of a trapped hydraulic jack handle.
PHONE: Tool for calling your neighbor Chris to see if he has another
hydraulic floor jack.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any
known drill bit that snaps neatly off in bolt holes thereby ending any
possible future use.
BAND SAW: A large stationary power saw primarily used by most shops to
cut good aluminum sheet into smaller pieces that more easily fit into
the trash can after you cut on the inside edge of the line instead of
the outside.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength
of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that
inexplicably has an accurately machined screwdriver tip on the end
opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under
lids and for opening old-style paper-and-tin oil cans and splashing
oil on your shirt; but can also be used, as the name implies, to strip
out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to
convert common slotted screws into non-removable screws.
PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is
used as a kind of divining rod to locate the most expensive parts
adjacent the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly
well on contents such as seats, vinyl records, liquids in plastic
bottles, collector magazines, refund checks, and rubber or plastic
parts. Especially useful for slicing work clothes, but only while
wearing them.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning
power plant 200 miles away and transforms it into compressed air that
travels by hose to a Chicago Pneumatic impact wrench that grips rusty
suspension bolts last tightened 40 years ago by someone in Abingdon,
Oxfordshire and rounds them off.
Old Feb 27, 2012 | 08:31 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
...Those are good...
Old Feb 27, 2012 | 09:38 PM
Tallguy67's Avatar
I read the rules of the forum today and realize that I cannot reply appropriately. So, in the place of an appropriate response, that is the funniest thing I have seen in a very long time!!!
Old Mar 8, 2012 | 11:51 AM
Lil Dog's Avatar
That was a full on laugh from me.. Great stuff!
Old Mar 8, 2012 | 04:17 PM
trksrfun's Avatar
This is funny and very accurate haha...
Old Mar 9, 2012 | 09:09 AM
98fargo's Avatar
So it's not just me? Whew!!
Old Mar 9, 2012 | 03:39 PM
Circle B's Avatar
LMAO!! Tim the Tool Man couldn't have said it any better. I think I'll make this into a poster for my shop...
Old Mar 9, 2012 | 03:51 PM
wrm's Avatar
wrm
Thank you i needed that
Old Mar 9, 2012 | 05:53 PM
Red_Angus's Avatar
nice
Old Mar 10, 2012 | 11:29 AM
NoSparkplugs's Avatar
So, so true!
Old Mar 11, 2012 | 11:34 PM
DJ Turbo.'s Avatar
Lil Dogs alive! and darn how true that is!
Old May 19, 2012 | 09:20 PM
45colt's Avatar
Holy crap , that hit the nail on the head,
Just a few days ago did the wire wheel what the....
That sound's like my hammer
ramlovingvet
Oct 25, 2002 04:00 PM
Nicholas
Oct 16, 2002 10:08 PM
