Dyno in Red Deer
Old Jul 7, 2009 | 10:26 PM
Lil Dog's Avatar
IIRC with the load settings on the Dynodynamics getting turbo boost isn't such a problem. I remember my run taking a good couple of seconds to build boost then off to the races. Its a variable load dyno. It tries to maintain a certain speed increase rate on the rolls no matter the power applied.
Wow, sounds good so far. I think the end of August would be OK.. after all the dust has settled from the AAB.
Old Jul 7, 2009 | 10:57 PM
dodgediesel's Avatar
What kinda of boost you pull during the run? You get lots of smoke? I try some methanol or NOS to get the twins to lite. Worst case is you could hammer on the brake to get the truck to load.
What kinda of boost is Brandon pulling on a WOT pull? He's running the HX-40/K-31 combo correct?
You bet but those turbo"s are really worked over with some Garrett parts and stuff. He's around 55 psi. it cleans up well too. Next is a intercooler and NOS.
Old Jul 8, 2009 | 09:08 AM
bigd450's Avatar
Originally Posted by dodgediesel
We hit the rollers yesterday at CCV with Brandon's truck with the PDR twins now. He hit 592HP. Just can't get past that 600hp mark!!!
They got the dyno working pretty good but it does read lower than AFI's dyno in Edmonton. We had that shop pretty smokey....
Brad said $100.00 per person but that gives you runs till your happy with the numbers. I'm sure we can work him down a bit for a first time diesel dyno event. He is super stoked for a event. Jason, let me know when you guys wanna have it and me and you can get it all flanged up.
Right on that's not bad at all. Maybe I will try out there dyno I haven't changed anything but would like to do more tuning. That would give a decent baseline to see how it compares to the Dynojet. What model of DynoDyamics do they have? Also really need to get my brothers truck dialed in soon so maybe we'll book a few hours one day.
Old Jul 8, 2009 | 10:10 AM
Right on!!!!!!
Old Jul 8, 2009 | 11:34 AM
Lil Dog's Avatar
I'd like to attend just to see the runs on those twins...
I remember talking to Myron about the dyno but can't remember the exact model.. I think its the 450DS, not sure if it has the aux retarder or not..
DynoDynamics 450 DS
Old Jul 8, 2009 | 11:43 AM
Mike Holmen's Avatar
The Guru
DodgeDiesel, hows the 40 set-up for the compressor/turbine? Which turbine housing/wastegate size and wastegate open pressure? Have you done any playing yet with the wastegate? I found that the lower wastegate pressure on the secondary allows the primary to load harder. You using the wastegate on the K-31?
At 55psi, the twins are just starting to lite/wake up
Old Jul 8, 2009 | 11:48 AM
Lil Dog's Avatar
Ok... Dumb question time.. I get confused between primary and secondary. I talk stages of compression in my day2day so is the primary the large first stage compressor?
Old Jul 8, 2009 | 11:53 AM
Lil Dog's Avatar
Select-a-date....Sorta..
When would the AB chapter like to do this event? Throw them out there as to your preferences and we can narrow it down from there.
Old Jul 8, 2009 | 12:12 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Once we get dates,I will post another tread..
Old Jul 8, 2009 | 12:16 PM
OMG Mike, you are speaking chinese to me brother!!!
All I know is that they are a worked over set of PDR Twins. Hybrid HX40 over a K31. They used to be on Brett Boyds silver Dodge. That 6 speed that was at the Blackout last year. His name is BOYDO on the DTR.
Old Jul 8, 2009 | 12:59 PM
The Guru
I have to take a look see at them. I'm curious on how PDR builds it for the 40/K-31 twins. I used to run my 40 at 22-24psi on the wastegate.
Old Jul 8, 2009 | 10:03 PM
Tate's Avatar
Follow the compressors. Primary is first stage.
I'll be game for for a dyno at the end of August or so. Sooner we hammer out a date, the sooner I can prepare for taking time off work.
Old Jul 8, 2009 | 10:24 PM
Lil Dog's Avatar
Tate, Thanks... Makes sense to me, just wanted to be sure.
End of August sounds like the ticket...
Old Jul 8, 2009 | 10:42 PM
How many weeks notice does Brad need if we book the dyno?
Old Jul 8, 2009 | 11:59 PM
About 3 weeks notice or so..
