Does anyone check the alignment with the run out dial tool ?
Old Jul 29, 2009 | 06:59 PM
roxxx's Avatar
I am reading the manual to install the nv4500 and just noticed they recommend checking alignment
MOUNTING STUD OR ROD
2 - DIAL INDICATOR
3 - INDICATOR PLUNGER
I might sound bit silly for asking but i have spent so friggin much money on this i just want to do it right
Old Jul 29, 2009 | 07:32 PM
Lil Dog's Avatar
Alignment? Is that from center to center of the flywheel and input shaft? Never did it on mine. Hmm.
Old Jul 29, 2009 | 11:43 PM
Tate's Avatar
Never done it on mine either. If the alignment is off, are you going to re dowel it? There is no way to check it and then set it once the tranny is inside the bellhousing without the dowels.
Not that its gonna hurt anything to check, but I don't see it being very far out. Whats the tolerance?
J, what they do is mount a mag base to the flywheel, and then run the dial on the ID of the input shaft retainer bore in the bellhousing.
Old Jul 30, 2009 | 12:36 AM
roxxx's Avatar
ok kinda figure I was sweating to much just way to much reading not enough seat off the pants thank you all not really looking forward to doing this
Old Jul 30, 2009 | 11:42 AM
Lil Dog's Avatar
Thanks Tate.. I saw that in the FSM you got me the link to but just forgot about it. I was in the same frame of mind, if its not good, then what? Worked when it came out...LOL..
Old Jul 30, 2009 | 01:37 PM
winkdemon's Avatar
likly the reason they tell you to check is the housing he have bought is a customs built one , and it's to save there A....S if it's wrong if you don't check it , but i have never had of one being bad .
Old Jul 30, 2009 | 05:09 PM
roxxx's Avatar
ok next question i cant find any torque specs as in the tranny to the bell housing and so on anyone have a torque spec sheet ? please
Old Jul 30, 2009 | 08:15 PM
Lil Dog's Avatar
NV4500 to the bell housing is 50 ft-lbs. Bell housing to engine 33 ft-lbs.
Old Jul 30, 2009 | 08:20 PM
Lil Dog's Avatar
Actually check that, the 2001 FSM states 80 ft-lbs.
Old Jul 30, 2009 | 10:20 PM
Tate's Avatar
Both those specs sound really high. They are 3/8" bolts into aluminum without heli-coils. Personally, other than the flywheel bolts and pressure plate bolts, I didn't torque anything there. You can usually feel when something is tight enough. Never had anything come loose on my trucks yet, and thats going on a couple years now.
Edit, my bad, I see its 33 ft.lbs for the bellhousing the engine adapter. That sounds about right.
Old Jul 31, 2009 | 08:43 PM
1-5-3-6-2-4's Avatar
we dial all engines that have an automatic behind it. far far more important to an auto that the housing be dialed and be within spec. we change them occasionally at work if one is out of spec. a housing out of spec in any measurement will take an auto out.
that said we never dial housings if it has a clutch.
Old Jul 31, 2009 | 11:18 PM
Tate's Avatar
Ironically enough, the only tranny you can do that with is the NV4500, as the G56, NV5600 and the autos have intergal bellhousing. If it can't be done with the other trannies, it can't be THAT critical in our application.
Old Aug 1, 2009 | 01:06 AM
what does the tranny bellhousing have to do with it?
you put a mag base and dial on the crankshaft, bar the engine over and dial the housing. for face, runout and concentricity.
Old Aug 1, 2009 | 01:24 AM
Tate's Avatar
Dial what housing?
Old Aug 1, 2009 | 01:27 AM
flywheel housing.
