Common Rail Injection Timing Questions??
Ya I could do some neat stuff. Anyways, its going to have to wait...Priced out some neat aquision equipment, you even can do some controls with it.
Anyways...
Thanks for the input guys & answering my questions. I still have lots to learn.
The timing parameters are quite vague on the CR Smarty & even vary from the Revo to the Revo TNT, but at least you can control the parameters with the Smarty.
With other programmers, who knows what they are doing with timing, pressure, etc...
To tune a fuel injected gasser, hours are spent on a dyno customizing the ECM programming. (My 5.0L Mustang has spent 2 x 4 hour sessions
on a dyno getting the tune right with a programmable ECM using a wideband O2 sensor).
I rarely hear of someone doing this with a diesel though. I would think that 4 hours on a good loading dyno with a Smarty on a modified CR would be the way to dial it in???
While the older engines do have some advantages, there are advantages to the new engines also.
The problem is you can't really tune to an A:F ratio like on a gasser, and EGT's aren't a reliable indicator of whats going on. You could definitely 'tune' to peak power with a programmer, but who knows what the longevity is because its still just blind guess work.
You can get O2 sensors installed at the tail pipe. I rather tune my stuff up on the fly as I'm driving. As good as dynos are, they can't adjust your tune for everything.
My best tuning device is to hook-up my RV and go find a big hill
, if I make it up, then I coast down, only to try the next one.
You find issues pretty quickly.
If you want a better understanding of how the timing tables work, go to efi lives site, download there softeware (its free) and go to dieselplace and download a stock file and take a peak at it, also download a modifyed tune for the same engine code. I find that dynamic timing makes way more sense since I got into the EFI live stuff.
danimal 95
Jan 8, 2008 09:36 AM
ddestruel
Jun 28, 2004 01:03 PM
