CNC manifold update
Old Sep 29, 2009 | 09:51 PM
roxxx's Avatar
CNC manifold update
Attachment 29737
Attachment 29738
Old Sep 29, 2009 | 10:00 PM
rage_blue's Avatar
? is that going to be two halves that bolt together?
Old Sep 29, 2009 | 10:07 PM
1-5-3-6-2-4's Avatar
thats the mould I think........I dunno. pretty wizzy though
Old Sep 29, 2009 | 10:08 PM
roxxx's Avatar
plasma
look on the web the other stuff he builds has hit some serious temps with no problems
http://www.steedspeed.com/videos
http://www.steedspeed.com/home here look at this
Old Sep 29, 2009 | 10:46 PM
dvst8r's Avatar
That is one baller looking manifold.
I hope we get to see some same day back to back comparisons vs an ATS manifold, as in my mind it is the current benchmark, I have seen trucks make over 1500hp on an ATS. I am quite certain Kevin, using the ATS, was in the 1300 - 1400hp range when that rod said that's it I'm outta here.
I would love to throw a manifold I built, into that comparison, but I have little hope I would be much competition for either that or the ats. Then again I doubt either of those will be offered in a dd15 or he351ve or ect... outlet flange.
Old Sep 29, 2009 | 11:12 PM
roxxx's Avatar
well he is all about power. so I imagine if he can figure out how to get a bit more out he will. best part of this he is grass roots and if he thinks there is a change to be made he will do it . not like bigger mass produced stuff, were it may take forever to get a change . Yes he is aware a lot of you are looking for External Waste Gates setups he does do them but baby steps
Just so every one knows I have nothing to gain from posting this on here . I like Steed and I like his work. I am hoping he will make me a manifold for my 1 st gen and hope fully he make you all some more HP. chances are you all will get a manifold before my old truck will .
If things go well maybe he can get some one to do runs on a dyno somewhere.
Feel free to direct your questions to Steed That way I wont get into trouble and say something stupid .. he is busy so please be patient
Old Sep 30, 2009 | 10:11 AM
morkable's Avatar
Not that it matters, but mine is a Htt, that was coated and ported.
Old Sep 30, 2009 | 10:52 AM
Homestead's Avatar
It says on his website they need a tester when machining is complete.
Looks like a very high quality piece to me anyways.
Jeff
Old Sep 30, 2009 | 03:37 PM
roxxx's Avatar
coated ? You mean ceramic right ? His will too
Look at some of the later BMW shots they are Ceramic coated as I image these will to plus I am going to talk to him about putting probes in to
I re read your post. how do you mean ported as in to match the head or smooth ? no rough surfaces ? it the later there is very Little machine surface left when the CNC is done, but I imaging you could go even further before the two are mated together and polish it
As far as matching it to the head and flowing the exhaust side yes it will be close but as it progresses he can fine tune the exhaust port to the manifold port
Old Sep 30, 2009 | 05:42 PM
morkable's Avatar
Ported to the gaskets to match the head yes. and the turbo
Old Sep 30, 2009 | 06:02 PM
roxxx's Avatar
yes to a point....
but as in any matching and porting you well know you need both head and manifold in a shop to grind to match. We just talked and he is aware of the port matching turbo and head .
I say at this point lets get some base numbers and build on them from there.
I think a guy from the other site is bringing him a CR manifold so he will be working on that too
Old Oct 1, 2009 | 12:06 PM
ARMOR's Avatar
Yeah I dropped him off a CR manifold this morning and looked at some of his other work...does an awesome job the welds everything down to the last detail is as professional as can be!!!!!!
Old Oct 1, 2009 | 03:44 PM
Tate's Avatar
Armor, are you doing testing on the manifold? I sent them a message if they needed testers, said they had a shop to do it already. Curious if it was you guys.
Old Oct 1, 2009 | 05:30 PM
roxxx's Avatar
Yes it is Tate , I think ARMOR has someone in mind
Think he might try doing back to back pulls on the dyno in red deer
Old Oct 2, 2009 | 11:00 PM
Mike Holmen's Avatar
The Guru
How is the truck set-up? Any details? I want to see the pit crew action on swapping an exhaust manifold for a dyno day outting. I bet that they aren't running twin turbos?
