OK before I call
Old Feb 17, 2011 | 09:50 AM
redlineguy's Avatar
OK before I call
I want as much info as i can get on some H&S stuff.
Which way should i go??
Black Max...
Mimi Max....
XRT Pro......
What is the Dif??
I plan to get the Overdrive trany tuning as well.
EGR delete...
Boost tube??
Intake manifold??
What else should I look at???
Thanks
Old Feb 17, 2011 | 10:32 AM
cbrahs's Avatar
I have done a lot of the minimaxx and they are very nice and compact plus you can unplug the HDMI cable and bring it in the house with you. Installation is very fast. if you are deleting cooler too, you can drill and tap the cooler delete plate for your EGT probe and get #6 temps. plus if you ever have to return to stock, there are no holes in the exh manifold. User functions are easy to follow.
also like the S&B filters for CAI
overdrive tranny software is a must.
Old Feb 17, 2011 | 12:33 PM
New2Diesel's Avatar
"Gomer Pyle"
My vote is for the Mini Maxx, or Black Maxx with the "Must Have" transmission tuning. The total amount of time it took me, alone, to install the full H&S EGR/Cooler Delete, Mini Maxx w/pyro and TV Delete was about 6 hours. I took extra special care because I did not want to dent/scratch my new truck and I wire loomed every single wire in the factory loom so if I had to remove for warranty work I could just leave the wiring in place. I have full installation photos and directions if you need them just PM me.
As stated above, tapping the back block off plate is a good idea as well. I did not do that but I probably should have.
desertchecker
14
Feb 18, 2008 09:32 AM
Javaluva
Oct 10, 2002 07:17 AM
