LED Reverse Light Wiring
Old Dec 7, 2010 | 10:04 PM
kevellis32's Avatar
Question LED Reverse Light Wiring
I just installed my Frontier Bumper replacements and on the rears I have the spot for reverse lights. Instead of using the cheap ones that were included I went and bought some LED ones.
While trying to wire them up I took out my tail light assembly and tied into the reverse light from there. I spliced the black wire from the bumper wiring harness to the white and red wire from the tailight harness, and the white(ground) wire from the bumper wiring harness to the black wire in the tailight harness. There is a third(red) wire that I didn't use on the bumper harness. I was able to get the cheap bulb lights that were included with the bumper to work properly, but when I would hook up the LED ones to the power source I couldn't get anything.
Do I need to add a resistor to the wiring? or am I hooking into the wrong places all together?
Old Dec 8, 2010 | 12:18 AM
Colo_River_Ram's Avatar
With age comes the cage
Try reversing the LED wires or hooking them directly to a battery for testing.. Some LED's will only work when properly polarized..
Old Dec 9, 2010 | 06:36 AM
bigjohn04's Avatar
Hook the red wire up instead of the black one and that should get the lights working.
Old Dec 23, 2010 | 05:13 PM
kevellis32's Avatar
You were correct bigjohn. Tried that and everything worked. Thanks for the help.
sojoe
Mar 29, 2014 09:24 AM
EPCO
Apr 10, 2011 05:20 PM
maddog1927
Jan 15, 2010 06:57 AM
Backwoods
Oct 18, 2008 05:49 AM
