race me tune
Old May 29, 2014 | 08:15 PM
2010dually's Avatar
race me tune
i have a 2010 ram 3500 410 gears just did full deletes 5 inch exhaust tuner is set at sw1 when i first loaded tuner setting came up fuel economy towing and perforamnce now when i hook up its says sw1 so im guessing that is on 40 horse tune does that add anything else i was looking to just delete truck nothing else trucks runs a bit better than stock but nothing to brag about any one have any suggestions on what to run to get best safe setup its an auto trans just want to be safe cant afford to fix a tranny right now will be pulling my fith wheel next weekend that weighs 16 thousand any help would be great
Old Jun 20, 2014 | 06:34 AM
71_340's Avatar
I am getting ready to delete my 2010 Ram today, using a RaceMe tuner.
So far I just updated the tuner to the newest software and had some email traffic with Franz from RaceMe. Anyway, there are two stock settings you can select:
One: X-Stock which unlocks you tuner from your VIN/ECM so it can be used on another truck.
Two: 0-Stock which gives you stock power settings but still allows you to run without a DPF and disables your EGR system (or you can remove it). THAT is the one you want.
How loud is your truck with the 5" system? I opted with a 4" down pipe and delete pipe. I don't like a lot of noise so I bought a Donaldson M090544 (51") muffler that I will install and will keep the OEM resonator as well. I am mostly interested in MPG gains and keeping soot and fuel out of my oil. I will post my results after I drive it for a while without all the emission stuff.
Old Jun 20, 2014 | 08:18 PM
2010dually's Avatar
So far so good I'm runnin 40 horse tune no smoke no soot oil is clean now best thing I ever did to truck mileage increase about 3 mpg go with 5 inch exhaust not loud was actually disappointed with sound I just hauled my fifth wheel 100 miles thru hills exhaust temp never went over 1000 my fiver comes in at 15000 pounds that's runnin at 70 mph if your runnin auto trans manual shift on the hills I run 5 th gear it will pull in 6 th but I'm keeping on the safe side lol only down fall I seen was exhaust brake doesn't work like it did when stock but my camper has disc brakes so I'm not really concerned about it but also when my truck was stock towing up hill my temp coolant that is was almost 240 now it never went over 204 awesome if ya have any other ?? Let me now glad to help dodge the best truck on the road period !!!??
Old Jul 20, 2014 | 02:51 AM
caycuse's Avatar
did a full delete 2012, race me jr tuner set at tow or sw2 gain 4.5 mpg no towing and highway driving 95 km
Blake Clark
21
Aug 21, 2012 12:35 PM
highrpms
Mar 16, 2008 08:35 PM
smoky05
15
Mar 14, 2008 07:08 PM
LinearX
14
Jun 14, 2005 04:48 PM
