Intake Throttle Valve
Old Feb 28, 2024 | 06:15 PM
Alexandergolden's Avatar
Will a code be thrown if the intake throttle valve is deleted? Also if I were to remove the ERG plunger and cap the cross over 1. would it throw a code 2. would I need an H&S or Smarty? Thanks
Old May 1, 2024 | 08:29 PM
haily grace's Avatar
I don't think this could happen !
Old May 2, 2024 | 08:19 AM
Thanks for the reply.
Old Sep 18, 2024 | 08:34 AM
RanniWins's Avatar
Intake Throttle Valve – Removing the intake throttle valve may cause a code to be thrown because the engine control unit (ECU) expects it to be there.
EGR Plunger Removal – If you remove the EGR plunger and cap the crossover pipe:
Code – Yes, it might throw a code because the ECU expects the EGR system to be operational.
Tuner – You will likely need a tuner like H&S or Smarty to adjust the ECU settings and prevent codes from appearing.
BEERGUT
31
Jan 7, 2017 11:37 PM
ZeroTolerance
Jun 15, 2011 12:56 PM
rossk
Jan 19, 2010 05:49 PM
SLEDGE
Dec 31, 2008 08:34 AM
