Guage Illumination wire?
There should be a fuse you can tap into to light up your gauge when you turn the switch on. I havent had a chance to install any gauges on one of those yet. I am sure some one can tell you exactly where the wire you are looking for is. I used the fuse tap, worked good for me.
DieselManor.com Home Page Copyright© 2008 DieselManor Inc.
NOTICE: You will receive a hard copy of vehicle specific instructions
with your purchase of DieselManor's ISSPRO gauge kit.
Gauge Installation on a 2008-2009 Dodge 6.7L Cummins
Click on images to enlarge
1. Thermocouple location and
installation procedure 2. Boost Gauge connection 3. Close-up Boost Bolt
4. Transmission Temp Gauge Sender 5. Fuel Pressure Gauge connection 6. Fuel Pressure Gauge connection
7. Location for wires and boost tube
through firewall (A/T) 8. Firewall plate removed. 9. Firewall plate with snap
grommets installed
10. Location for wires and boost tube
through firewall (M/T) 11. Factory dimmer switch. 12. Gauge Illumination source
13. Switched Ignition Source
(Power source) 14. Grounding location
grommets installed
The easiest way to get power to spare inside of the cab is to use the Painless cirkit boss. Geno's has a great price on the 7 circuit kit. Two wires out side through the rubber boot in the firewall and the self contained fuse block with 7 wires (four battery hot and three key on, or maybe vise versa) One main gets hooked to the battery and the other to a key on in the trucks fuse block. Very safe and easy. I had it on my 04 truck. I just kept the spare wires taped up inder the carpet on the driver side. If I wanted to hook somethin up inside of my truck I had plenty of options.
http://www.genosgarage.com/prodinfo....70107-PAINLESS
PZM123
Apr 15, 2006 09:32 AM
TPilaske
16
Nov 22, 2002 08:15 PM
