Everything is ordered!!!!
Old Apr 17, 2011 | 06:33 PM
ramdiesel23's Avatar
Well, after much research,reading, and asking around, I ordered everything up for the leveling kit. I went with Lorenz coils(they were the only true 2inch coils I found and I didn't want much more cause I tow everyday), bilstein 5100s all the way around, new end links, bilstein 7100 steering stabilizer, carli adjustable track bar, kore bump stops, 35 toyo mts, and mag hytec front and rear differential covers. Anything I'm missing?
Also coming soon is a new steering brace, deletes, and the minimax. Any recommendations on steering braces. I had the bds on my last truck and it seemed good. I know this isn't a huge build up but maybe it will help someone else who is up in the air on what leveling kit to go with. Will have pics when it's finished. Wouldve liked to go with the 3inch with the new leafs in the back but wanted to lift it as minimum as possible to fit the 35s.
Old Apr 18, 2011 | 07:16 AM
RAMRODD's Avatar
What truck are you putting this on. I don't think a 4th gen needs a steering brace.
Old Apr 18, 2011 | 07:59 AM
cbrahs's Avatar
steering brace is cheap insurance to protect a steering box.
Old Apr 18, 2011 | 05:17 PM
2011 4x4 srw megacab. The steering brace definitely helps once you put the bigger tires on.
Old Jul 5, 2011 | 09:03 PM
wlowe's Avatar
So how did your leveling kit install go? Curious to see how you like the Lorenze coil springs. I'm thinking about getting these also.
Old Jul 5, 2011 | 09:51 PM
Rednecktastic's Avatar
I have a similar set up on my third gen and if he still sells the leaf pack for the rear I'd suggest getting it. Little lift and it rides better.
hotdram
Sep 10, 2005 04:09 PM
MOREPOWER
Jul 28, 2005 05:08 PM
G1625S
Apr 7, 2005 01:33 AM
mr T
Oct 4, 2004 09:06 PM
shortfieldbreak
Nov 11, 2002 03:03 PM
