Carli leveling kit install tips
Just got my new Carli leveling kit, planning on trying the install this weekend, looking for tips and advice, never done a level kit with the spring coils before. Carli support said support and raise frame, let axle hang till it is free, then undo track bar and take coils and shocks out and put new ones in. then install new track bar and sway bar end links, put pressure on track bar and tighten, also no special tools are required. Hope this goes smoothly, planning on monday taking it to get new 315's and add a extra leaf in the rear. Any feedback would be appreciated thanks and happy holidays.
Only thing I see there that I would do differently is don't let the axle completely hang free off the ground then unhook track bar, there will be force on.
What I did and worked well was start lifting the frame and when you have the tires just about to come off the ground but still on, then unhook the track bar. The axle won't move on you and the bolt is easy to pull out, then continue raising until you can get the springs out. Hope this helps |
Is this the full spring/shock kit or just the level spacers?
The Carli kit has springs, 5100 shocks and end links.
This is the new springs, new shocks and sway bar links kit plus the track bar... after I unhook track bar is it really that simple as drop axle down and u can pull the old springs out and unbolt the shocks, then put new ones in? Seems almost to good to b true, lol. Thanks to this forum otherwise probably would have got spacers great advice from good friends
One thing that should help. Unbolt the track bar on the frame side. This will allow the front axle to droop out more so you can get the coils out/in easier.
Originally Posted by easymoney21
(Post 3049002)
Ok ok, been trying to put kit on, old coils where 19" tall, new ones are 25" tall, I couldn't get the truck high enough so i had to use a compressor to get them down to 22" tall so i could get them in. Now trying to get shocks in, Bottom bolt would be a lot easier if i took steering components loose, but hate to do it. Way things are going its going to be a long weekend. lol
(Post 3049270)
I am hoping the track bar and the swaybar end links install go smoother tomorrow. When I called carli on friday they gave me a brief summary of what to do, they must have only gave the highlights, when i did my own install of the full H &S delete they had a awesome step by step with pictures. Told of what things to look out for, was really nice.
Got it done finally, what I learned; needed coil spring compressor, more then one person to do install. Biggest fights where getting axle side of trac bar in, Bottom shock on passenger side was a pain to get line up unless you took steering components loose. Easy parts where the sway bar link extensions. also take brake line mounts loose and vent tube mount so you dont stress them dropping the axle down. Now to add a spring on the back and to get the new tires and rims on. Thanks for all the help.
when i put my Carli Coils in, I unbolted the lower control arms as well as the above mentioned parts , it made it way easier to get enough room/play to stuff the new coils in with out compressors
lets see some finish photos, I am trying to decide on the leveling kit or starter kit. I am looking at improving my ride as much as lifting truck.
(Post 3049615)
Got it done finally, what I learned; needed coil spring compressor, ....
Thanks for the tips! UPS man dropped all my carli stuff off yesterday. I'm lowering from 6" to 3"+ w/deavers in the rear. So siked to get this stuff on and get rid of the SKYJUNKER stuff!!!! After a few years, truck is about 100% of where I want it to be.
