2012 3500 with lighting bolt and check engine after delete
Old Sep 17, 2019 | 10:32 PM
nvr-enuf's Avatar
Hello everyone,
Friend of mine has a 2012 3500 with a mini max controller in which a delete was performed, various pieces were removed: air intake valve (like a throttle body), EGR valve, and EGR cooler.
The red lightning bolt and check engine light is on. Has anyone ever experienced this / do you konw what I need to do in order to not have these codes show up? I tried using a code reader but nothing showed up. I will see if oreilys can see my codes tomorrow
Thanks
Old Oct 1, 2019 | 01:00 PM
nvr-enuf's Avatar
Figured out
Ended up being the MAP sensor was disconnected which makes sense since this was needed to be disconnected in order to get the Throttle valve removed in order to disconnect that connector.
All Good
nvr-enuf
0
Sep 17, 2019 03:11 PM
JSD
0
Feb 28, 2019 08:13 AM
rowekmr
0
Mar 25, 2017 03:43 AM
mikey59
Aug 2, 2016 03:43 AM
dodgeman5902
Nov 18, 2014 11:53 PM
