4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Two Differant readings??
Old Jun 2, 2011 | 08:18 PM
retiredchuck's Avatar
Unhappy Two Differant readings??
I was standing at idle and the temperture gauge readout was 200 and the oil pressure gauge readout was 40.BUT at the EVIC the temperture was 170 and the oil pressure was 29.Which one do I belive??? they should be the same???Anybody out there have a idea as to why??Or have the same situation??Thanks in advance
Old Jun 5, 2011 | 09:14 PM
77 veiws and no one has a input?????????????.Next time you drive your truck check it out.
Old Jun 6, 2011 | 05:02 AM
redlineguy's Avatar
Never saw that, Will keep an eye on it.
Old Jun 6, 2011 | 07:10 AM
Chuck Diesel's Avatar
I don't watch mine often but the times I have checked them they both read the same. I have about 11k miles on my 2010 with no issues...."fingers crossed"...hope I didn't just jinx myself there.
Old Jun 6, 2011 | 11:16 AM
6 Shaker's Avatar
Don't believe either gauge reading as they are just a made up number. There is just an oil pressure switch so the computer just tells you what it thinks it should be and not what it actually is. If you want to know your real oil pressure you will need to install an aftermarket oil pressure gauge.
I added an oil pressure gauge to my '06 and its reading was WAY different from the factory gauge. It was very interesting to watch, especially when towing when the oil would heat up.....
Old Jun 6, 2011 | 04:59 PM
New2Diesel's Avatar
"Gomer Pyle"
I have beat the snot out of my truck and have never ever seen 200 for a water temp.
Old Jun 6, 2011 | 09:52 PM
Blake Clark's Avatar
Read this earlier, and, today while in the big city (Lafayette) I took notice that neither differed by more than 3 or 4 degrees/psi of each other.
Now, as 6 Shaker said, whether or not to trust them is still out for debate.
Old Jun 7, 2011 | 08:49 PM
Thanks guys, Its a shame that with a truck this expensive you don't get decent gauges.
stock600
Nov 28, 2007 03:58 PM
fishin fever
Aug 4, 2005 09:47 AM
fishin fever
Jan 15, 2005 12:35 AM
Dan3667
May 3, 2004 07:05 AM
AKDSLDOG
Mar 14, 2003 05:38 PM
