Rough idle 6.7
Cummins Guru
Possible injector or connections in valve cover wiring harness, I would try injector cleaner first dump two bottles of cleaner in the tank. I use CRC recommended for diesel engine injectors. Check for any stored codes.
Do you have the manual or auto trans? Is it deleted or stock? Maybe let us know what year your vehicle is and what all mods you've done if any. That would help narrow the chase a little.
Remove the pressure/temp sensor in the intake manifold and inspect it, one torx screw. The one on our G56 truck was so bad it had to be replaced after only 20,000ml while we were able to clean the one on the auto truck at about 5000ml..
banks twinram
May 18, 2010 08:10 PM
turbov6joe
Sep 25, 2003 10:57 AM
