loss of power around 2000 rpm, need recommendations
Background: 2010 Dodge Ram 2500 SLT RWD 6.7 Cummins, 220,000 miles, purchased from nephew who bought new, Smarty tuner with EGR deleted, was running towing setting on Smarty.
On occasion, I would notice a hiccup while driving, but, nothing consistent. Many times, I would change the fuel filter and any hiccuping would seemingly go away.
Now the truck noses down around 2000 rpm. It is drive-able, if I stay in it, but with significantly less power and the engine sounds "hollowey". I have to let off the pedal because of the power loss. When I let off the pedal, the power will return in a few seconds after rpms have dropped way down and the "hollow" sound goes away.
First item up on the agenda was the fuel filter. I replaced it with no effect. I have replaced the lift pump with a Fleece unit and replaced the filler neck. I started there because I thought my rusting filler neck might have damaged the lift pump. Starting has gotten easier, but problem remains. I then replaced the CP3 fuel injection metering unit with a Bosch replacement, no effect. I then replaced the rail over-pressure device with a plug, no effect. I then replaced the rail pressure switch with a Bosch unit, no effect. The next item up on the agenda appears to be the CP3 pump. Does anyone have any suggestions for me? Before I started working on it, I returned it to the factory tune and checked for DTCs. There have been no DTCs this whole time.
Back to morning brew . . .
turbo swap
Thanks. Indeed it was. I have a 10 month old at home that takes up all my time. I finally got the stocker swapped out with an Aurora 4000 VGT and the nosing down has ended. I suspect the actuation process was gummed up. With the stock tune it pulls hard. I am not sure I want turn it back up. I might roast my 68RFE.
randallp84
65
Mar 11, 2009 01:06 PM
OutOfSight
Oct 27, 2007 12:27 AM
