4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Gearing Advice
Old Aug 27, 2011 | 06:22 PM
gibby560's Avatar
Gearing Advice
Bought a 2011 3500 4x4 6sp dually and did not pay close enough attention to the gear ratio. Came with the 3.42 and I tow a lot for my construction company. The 3.42 is not enough and want to go to either 3.73 or 4.10. Looking for advice. Tow loads upward of 18k goosneck.
Old Aug 27, 2011 | 07:27 PM
Delmar's Avatar
My truck has the 3:42 rear end and my car hauler weighs upwards of 20K. I love the 3:42 rear, with 1st gear being a granny gear it does great in town and is way better on the highway.
I think your money will be better spent on a tuner and deletes.
Old Aug 27, 2011 | 10:25 PM
turbo246's Avatar
What rpm are you running at 65?
Old Aug 28, 2011 | 06:17 AM
gibby560's Avatar
I am running about 1700 rpm's.
Old Aug 28, 2011 | 11:26 AM
dmurdock's Avatar
Tow in 5th...it will be the equivalent of towing in 6th with 4.56's...
5th is the direct gear too...
Old Aug 28, 2011 | 06:24 PM
gibby560's Avatar
Appreciate all of the responses. I don't like towing in 5th on the interstate, I would like to keep the motor around 2000 rpm's and keep some speed and the truck pulls real well at this rpm. As far as the tuner and deletes, will the stock clutch hold up to the power? Looking at the H&S site the power increase is significant.
Old Aug 28, 2011 | 06:59 PM
RickCJ's Avatar
X2 that'll put around 2500rpm in direct drive right where you should be towing 18k
Old Aug 28, 2011 | 08:03 PM
gibby560's Avatar
If towing in 5th is the answer; what do I do about getting the load going? Truck is not a huge fan of this either.
Old Aug 28, 2011 | 10:15 PM
dmurdock's Avatar
If it's 2WD swapping out rear gears may be worth the $$ to you but it still won't be cheap...but probably the cheapest option. Other option I can think of is gear vendors over/underdrive but you're talking some serious $$.
Old Aug 28, 2011 | 10:39 PM
Spooler's Avatar
G56 manual and 3.73 will put you at about the same as an auto and 4.10 gears. You should be good if you do that and you will keep your warranty. The clutch is the weakest link with the dual mass flywheel. If you turn it up, you will need a clutch real soon.
Cranking out 2500rpm would not be an option for me either. That will eat some serious fuel.
Old Aug 29, 2011 | 06:33 AM
PsRumors's Avatar
Should have just bought the right truck to begin with.....what an idiot
Old Aug 29, 2011 | 05:47 PM
Spooler's Avatar
Actually, this happens all the time. People mess up and get the wrong gear ratio.
Old Aug 29, 2011 | 06:37 PM
gibby560's Avatar
Sorry if you feel like I am an idiot, that is your own problem. FYI, this is the first new truck purchase I have ever had and I am proud to have this truck. It is people like you who run off newbies like myself. If you have nothing constructive to say please do not respond to any of my posts, I am sure I will do something stupid again and just wish I could be as perfect as you think you are!!!!
Old Aug 29, 2011 | 07:09 PM
dmurdock's Avatar
Shouldn't you be in school?
Old Aug 29, 2011 | 07:39 PM
PsRumors's Avatar
Well you must be an idiot....you don't know how many new trucks you have....you posted in another thread you had TWO 2011s so which is it?
And yes, I agree....you probably will do something stupid again
