4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Filter under valve cover
Old Aug 23, 2012 | 01:38 PM
ranchertx's Avatar
I am told that there is some kind of filter under the valve cover of my 2010 Cummins that needs to be changed every 50-60,000 miles. My truck is deleted and has been since 2500 miles. Does anyone know anything about this filter? How hard is it to change out?
Old Aug 23, 2012 | 02:37 PM
BigIron70's Avatar
Cummins Guru
changed at 67500 miles, very easy to change. Just need 8mm socket, 1/4 drive with extention. Lift cover off pull out filter install new filter ten minute job.
Old Aug 23, 2012 | 04:21 PM
ranchertx's Avatar
OK thanks Big Iron, do you need a valve cover gasket or does the old one work?
Old Aug 23, 2012 | 05:00 PM
aketay's Avatar
I think it is part of the new filter.
Old Aug 23, 2012 | 07:18 PM
BigIron70's Avatar
Cummins Guru
Reusable, just make sure it didn't come out of the valve cover when reinstalling cover over the filter. Service required will showup on dash display at 67500 miles. Press brake twice and gas pedal twice with key on then key off to reset service minder.
svtrich
13
Dec 23, 2008 07:20 AM
displacedtexan
17
Dec 7, 2006 09:13 PM
n5oxp
Sep 20, 2005 06:19 PM
suzukiZrider
Jan 13, 2005 08:20 PM
Richard Cox
Feb 14, 2004 07:54 PM
