4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Check Engine Light
Old Dec 13, 2014 | 11:45 AM
rving4us's Avatar
Check Engine Light
My check engine light came on 1200 miles on the truck. Had auto Zone put a scanner on it it showed U3017, but would not tell what it is. Any Ideas? Is it safe to drive the truck? it is my daily driver now.
Thanks
Old Dec 13, 2014 | 03:30 PM
Hillbilly66's Avatar
Take it into the dealer when you can, they will need to do a software update to get rid of the code
Old Dec 13, 2014 | 09:42 PM
BigIron70's Avatar
Cummins Guru
There is a PCM flash update and DCU update that needs to be done.
Old Dec 13, 2014 | 10:24 PM
Albertaguy's Avatar
I had the same code come up last week and they flashed my computer. Something to do with the ignition switch. There was a TSB on it. On my work order it says they reprogrammed my DCU and PCM.
I am still trying to find where I can get all the codes not just the P codes.
Old Dec 14, 2014 | 04:34 PM
BigIron70's Avatar
Cummins Guru
There are about 24 modules and each one has about 50 codes the PCM has about 150 codes do the math.
buddy26
Feb 15, 2008 12:17 PM
choppers555
Oct 16, 2007 12:29 PM
alltimelow1
Apr 6, 2005 07:28 PM
Fillerupsonny
Oct 9, 2002 06:01 PM
