4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
2011or2014?
Old Jun 16, 2014 | 12:06 PM
Busboy's Avatar
Originally Posted by Silver goat
I am at the point where I think I should get rid of my 2001 and upgrade. I was going to buy a new 2014 but a neighbor down the street has a 2011 truck with low miles and a good price. I do not know a lot about the 2011 and have tried to read as much as possible but I wanted your thoughts. I know the 2011 is not a brand-new truck but it only has 33,000 miles and he is selling it because he is selling his camper. I know if I delete I will get better fuel mileage but overall, is a 2011 a good truck. It's a 1 ton 4x4 4 door dually. Thanks
Check the gears on the 2011 and if 3.42 or 3.73 get the 2011 and delete it the movement you get it, warranty is not worth the long term damage that's being done to the engine. Other than the addition of a fuel cap to the 2014 it's pretty much the same truck as the 2013. Forgot to mention my son is now looking for a new 2012 to replace his 2013.
Old Jun 16, 2014 | 02:26 PM
jadocs's Avatar
I think there is more changes between a 2013 & 2014 than just a fuel cap. Aren't the frames totally different/upgraded? I know on the 2500's they come with rear coils and the thing rides like a Cadillac.
Old Jun 16, 2014 | 02:33 PM
Busboy's Avatar
The difference is between 2012 and 2013, the 13's didn't come out until May 2013 and have the heavier frame and higher GVWR which speaks for nothing if it won't idle in the cold, admitted the 2011/12's didn't either but you could delete them so they would work in the cold.
Old Jun 16, 2014 | 03:04 PM
Silver goat's Avatar
I was looking at the raceme and delete pipe.. Is this a good set up? The thing already has twice as much horsepower and torque as my 01, so I don't want a power increase just reliability. I have fixed a lot of things on my 2001 over the years thanks to this website and I know nothing of the 6.7. Has anybody ever had any problems because they deleted?
Old Jun 16, 2014 | 07:25 PM
Busboy's Avatar
In my 2011 I'm using the H&S mini max with their transmission tune, I run on mild and only deleted to make it run in the winter, it has more than enough power to tow my 13,700lb 5ver in the mountains. The truck has never thrown a code since I deleted over 3 years ago. Sorry no experience with the raceme.
Old Jun 17, 2014 | 05:33 PM
Busboy, did you do a full delete or pipe and tuner?
Old Jun 17, 2014 | 07:36 PM
Busboy's Avatar
Full Delete and CCV delete on both 2011's one manual one auto trans, it made the trucks into what they were supposed to be and cleaned up the engine bay plus gave a spot to mount the EGT probe in the rear EGR cooler delete plate without having to drill the manifold. If you buy a new intake you don't need the full EGR delete kit only the cooler delete part. I should add that you read the thread that Blake posted it will set you on the right track. https://www.dieseltruckresource.com/...t-t278158.html
