key fobs
ok her's my situation
the truck 2008 sterling bullett 4500 originally did not come with the keyless entry, and everytime the battery gets disconnected there is a red blinking light on the dash. the only two ways as far as i know to turn this light of is to hook up the laptop clear the code, or use the key fob. allright so i didnt want to hook the laptop up everytime to turn this light off so i ordered in the skreem wcm to replace the older one. now when i tried to program the keys, it matches the vin, enter in the vehicle key pin, and then it says cannot find the secret key. so basically since i never had a secret key originally everyone says im boned. heres my issue is i have another bullet that was ordered in with the keyless entry both have the same pcm/ecm part number. which is the module the wcm needs to learn the secret key from. so one truck can be programed with a secret key the other cant... also the sterling technical support couldnt help they told me to call the local dodge dealer. using starmobile to attempt this ordeal |
