Conventional towing with 5500
Hi guys, I've been searching all over and would like to hear from people that tow 20k with their 5500s (not with gooseneck or 5th wheel though). My plan is to get a 5500 flatbed (4.88 gears and Aisin) that will be loaded to capacity 19,500 gvw (including tongue weight). Behind the truck I'd be pulling a triple axle flatbed weighing in around 19,000 lbs. with either a heavy duty 20k receiver or pintle. This will put the truck at the max gcwr of 38,500. I know it's legal, but for you guys that tow loads like this, how does it really feel? I wouldn't be loaded this heavy all the time, probably 20 times a year.
Also, the trailer will be set up with electric over hydraulic disc brakes to all three torsion axles.
I would really appreciate any input.
Kudos for using the proper truck for the job. There was a goofball on the 1st gen page a while back that wanted to tow 40K behind a 1st gen truck. Bunch of people told him it was a bad idea (and buy the proper truck for the weight) but he did it anyway. Then he cried for help when his automatic trans grenaded 200 miles from home. He's lucky he didn't kill himself or someone else.
4500 verses 5500
Purchasing a 4500 or 5500 ram. Looking at 4500 with 4.44 rear end or the 5500
with 4.88 what kind of fuel mileage can I expect out of each. Probably pull a 40 PJ trailer with average load of 13,000 lb. Any advise on do and don'ts would also help.
Towing 20k with a 5500 flatbed is doable, but there are a few things to think about. Since you’re using a heavy-duty receiver or pintle hitch, make sure it's rated for the weight. Being at the max GCWR means the truck is working hard, but it should handle it as long as everything is set up right.
With electric over hydraulic brakes on all three axles, you’ll have good stopping power, which is important when towing this heavy. The Aisin transmission and 4.88 gears will give you the power and control you need, but you might feel the truck working more on hills or in tough conditions.
Since you won’t be loaded this heavy all the time, the truck should be able to handle it for those 20 trips a year. Just make sure you check your brakes, tires, and other components regularly, especially after long or heavy hauls. Some drivers say the ride can feel a bit rough with max loads, but if you manage it carefully, it should be fine.
Let us know how it goes!
Wulfdiesel
22
Oct 21, 2007 06:19 PM
truckjunkie
20
Nov 3, 2005 08:50 PM
j-dubya
15
Oct 16, 2005 09:28 AM
