Wiring terminals for the power window switch connector?
Cannot find the right terminals to repair the blue pin connector that plugs in to the drivers window switch panel. Had one short out, melted the plastic that surrounds the pin which coated the connection. Only way I could see to fix it was remove and cut the offending terminal and try to find a replacement. Long story short, I can't find this terminal, any ideas?
picture maybe would help some for use that don't have a 3rd gen to look at
Pictures
4 Attachment(s)
Pics
Check out Mouser Female Disconnects They have some that look like what you're wanting.
Went by the dealer today, was able to get a replacement connector to some other chrysler car. Basically it had the same female connectors already crimped onto some new wire, I simply cut one off with a length of wire attached and crimped it onto the old wire with a copper sleeve, heat shrinked it and it is now fixed.
Thanks fo reporting back. A lot of times we try and help and never here what happened.
Yea, I hate threads that end up that way. Especially when you do a search and the thread just leaves you looking for an answer.
