Want to sound deaden your truck? I have some advice...
Old Mar 16, 2010 | 10:48 AM
stock03's Avatar
Originally Posted by kry226
The below quotes are from a guy who started testing every sound deadener material on the market about four or five years ago. .."
Very interesting. Thanks for that info too. Looks like asphalt is out of the question.
Old Mar 16, 2010 | 03:29 PM
kry226's Avatar
Originally Posted by BroncoAZ
I'm mid project on this right now. I'm using the butyl foil lined Raam Mat. I purchased the materials a couple of years when I had my Titan and never got around to installing it. I had purchased two 62 ft^2 rolls of the mat and 6 yards of their 1/8" closed cell foam. I saw that Raam now sells self adhesive closed cell foam, so I will probably end up using that rather than screwing with spray adhesive. So far I have used one complete roll of butyl mat doing the back wall, rear pillars, and entire floor of my regular cab. I'm sure the 100% coverage is overkill, but I've got plenty of material. I didn't do any closed cell foam under the floor carpet as I thought it might affect the fit.
There is a substantial difference with just the back wall and floor done. I haven't done the doors or roof yet. I'm planning on doing 100% coverage on the roof and inner/outer doors. I am going to make some panels to seal up the large openings in the inner doors, I haven't decided if they will be metal or plastic. I was thinking ABS plates would work and I'll use silicon to secure them. I have enough material that I'll probably do a layer of mat over those too.
I did score 2 boxes of the Dynamat hood liner for $10 each at Fry's Electronics. It is the 3/4" foam with foil liner. I used most of one box under the OEM liner of the hood. I'm going to see how much of it I can put in the roof. I figure the foam and foil will help insulate the roof from the scalding AZ sun. If I have any left I'll find a place for it.
I did some major audio upgrades with the first stage of sound deadening, so far so good.
Let us know how it turns out.
Old Mar 16, 2010 | 08:13 PM
BroncoAZ's Avatar
I had used the asphalt based matting in my Bronco back in the late 1990's. I pulled the door panel last weekend and found most of it was peeled off, some had fallen into the bottom of the door.
As for the Dodge, we did the doors with the raammat butyl product this past weekend, I'm glad there are only 2 of them as it took longer than I remember on my previous trucks. My wife was nice enough to help, and her small hands are great for getting inside the door. The outer door skins are probably 80% covered, leaving room at the bottom for drainage. The inner door panels are 95% covered with plates covering up the three large holes that let the noise in. I didn't get much time to drive the truck Sunday before leaving on a business trip, but the initial impression is less road noise and better midrange response from the speakers. We used about 12 ft^2 on each door. I took pictures, but I don't have them with me on my work computer.
I may go back in and add several layers of the closed cell 1/8" foam between the inner door and the door panel, but I ran out of time last weekend. I still need to do the roof and A pillars, and if I get brave I'll do some work behind the dash.
Old Feb 23, 2015 | 04:06 PM
hydraulicman's Avatar
sound deadening
What are the companies you used for this job?
Old Feb 25, 2015 | 06:10 AM
kry226's Avatar
Replied to your PM.
Old Feb 25, 2015 | 06:23 PM
Country23047's Avatar
I never noticed that much of a problem. It's a 3/4 ton truck and not your father's Buick.
Old Feb 25, 2015 | 09:17 PM
kry226's Avatar
Thanks for adding to the conversation with some quality insights! [thumbs up]
Old Apr 17, 2015 | 01:11 PM
m-o-p-a-r's Avatar
Everything you could want/need, both products and knowledge, is right here: Welcome to Sound Deadener Showdown | Sound Deadener Showdown
Old Nov 6, 2022 | 10:17 AM
Jcostello's Avatar
Replied to your PM.
I know this is an old thread, but would you mind telling me what brand(s) you used?
Old Nov 6, 2022 | 02:21 PM
kry226's Avatar
See post #23. I used the Sound Deadener Showdown stuff.
Old Nov 6, 2022 | 03:58 PM
Jcostello's Avatar
Thanks. Unfortunately, I don't think they're in business anymore.
Old Feb 13, 2024 | 10:00 PM
JR Troyer's Avatar
Great advice
i would be interested in your videos and photos or any other info that would help me do that to ,y truck
Old Feb 13, 2024 | 10:03 PM
JR Troyer's Avatar
Sound proof
I would like the videos and photos and all the info you could share that would help me sound proof my truck
prkiller
14
May 16, 2007 02:11 PM
FishingFather
Sep 20, 2006 04:57 PM
I PASS GAS
Jan 25, 2006 07:51 PM
Missouri_Mule
Dec 11, 2002 04:20 PM
