Torque Specs
Old Nov 9, 2009 | 02:36 PM
Gringo's Avatar
Torque Specs
Can one of you all knowing Cummins dudes give me the torque specs for the mounting bolts on the Steering box for an '03 4x4 quad cab 3500 Cummins?
Thanks
Old Nov 9, 2009 | 03:10 PM
SAVOY1964's Avatar
INSTALLATION
(1) Position the steering gear on the frame rail and
install the three mounting bolts (Fig. 4). Tighten the
mounting bolts to 196 N·m (145 ft. lbs.).
(2) Align steering coupler on gear shaft. Install
pinch bolt and tighten to 49 N·m (36 ft. lbs.) torque.
(3) Align and install the pitman arm (Refer to 19 -
STEERING/LINKAGE/PITMAN ARM - INSTALLATION).
(4) Install the washer and retaining nut on the pitman
shaft. Tighten the nut to 305 N·m (225 ft. lbs.).
(5) Connect fluid hoses to steering gear (Refer to
19 - STEERING/PUMP/HOSES - INSTALLATION),
tighten to 31 N·m (23 ft. lbs.).
(6) Add fluid, (Refer to 19 - STEERING/PUMP -
STANDARD PROCEDURE).
(7) Reset the toe and center the steering wheel
(Refer to 2 - SUSPENSION/WHEEL ALIGNMENT -
Old Nov 10, 2009 | 09:54 AM
Gringo's Avatar
Much appreciated.
lniemeyer2
Oct 24, 2012 12:11 PM
06RAMCTD
0
Dec 19, 2006 04:15 PM
docwes
Jun 2, 2003 11:01 AM
MnTom
May 16, 2003 09:08 PM
Lary Ellis (Top)
Feb 23, 2003 01:10 PM
