That Thumping in the front again..
My track bar was loose, but didn't seem like it. The hole had a slight wobbed out look to it. I used a breaker bar and a pipe and really laid into her. That tightened it up and the noise is gone. I know you think it's tight, but I'd suggest getting medieval on it's ***. I'd bet money that's the problem when you turn.
I haven't heard of one breaking, although I have rounded the axle side off a bit before (limited access). The OEM metric bolts are the equivalent of Gr8. The torque spec on them is 153ft-lbs, which absolutely requires a breaker bar or an impact gun, but using the oversized SAE fine-thread I've been able to generate well over 200ft-lbs in the driveway.
Well its seems like the Shocks took of it for the time being.. Im still amazed that my ball joints are still in working order after reading about all the ones that went bad with low mileage, some as low as 40K miles..I wonder how many of them were really put through hell and failed .. "what a truck shoud be able to handle"...
Reading through all the pages of failed ball joints, there is a wide range of miles that most trucks had, no smoking gun, no evidence/trend that they were failing at one certain time, I tend to think that many of these early failures were caused by driving habits..
One last thing I do recall, the school where my daughter goes put in speed bumps last year.. i hit those things kinda hard every now and then,,and laughed about it...not long after I remember now the noise started in the front.
Here is a old pic I found that shows the bolt that I had problems with. It could also, I guess, be a problem with the opposite side bolt too. Hope that helps.
I had a slight clunk in my front end and took it in before warranty runs out. The dealer changed something called a transition bar in the steering column.
It was less that 2 feet long, a universal joint at one end and a sort of U, that matches to a square shaft, I guess, and a bolt goes thru it, at the other end. I was told that that U is a weak point and when steering at slow speed or stopped the U will open up and the result is a clunk under certain conditions.
Bob
