speedometer problems!
Old Aug 7, 2007 | 09:42 PM
moonshinedoc's Avatar
I didi a search and came up with some things to check but wanted to run it by y'all to see if there was anything else. I started having problems with my speedometer the oter day, I noticed that I had everything except for speedometer reading, then every once in a while it starts to jump around and then it will work for a little while and stop. I have checked all the fuses I think is related but came up with zilch! Does anyone have a clue what could be going on or is there a relay or fuse I may be missing? Thanks for the help.
Old Aug 8, 2007 | 06:11 AM
Blue600's Avatar
Check the connection on top of the rear differential. It reads the tone ring inside.
Old Aug 9, 2007 | 09:47 PM
Thanks I will try that!
Old Aug 9, 2007 | 09:55 PM
vzdude's Avatar
DTR's 'Go to Guy'
Check for codes. key off/on, off/on, off/on leave in the on position the last time . Codes will show in the odometer screen.
Old Aug 10, 2007 | 11:44 AM
2003Ram's Avatar
I have a speedo problem too. When I'm not looking, it shoots up to 80mph!! Dang Smarty.......
Sorry I can't help with the issue. Post what you find out about the connection on the diff.
case5555
Dec 22, 2009 07:13 PM
Shrek86
Sep 7, 2007 05:46 PM
m1guy
Dec 20, 2006 10:17 PM
AggiePhil
Mar 15, 2005 08:20 PM
TexasBlake
Feb 23, 2004 01:26 PM
