See the dealer. . . . Maybe someone can see them
I have a great relationship with my dealer. . .
08 2500 with 60K on it I am getting a service soon message on my Overhead when I first start it. All the work has been done, even the crankcase filter. Every time I change the oil, I reset it with the fuel peddle 3 times. But when I rolled over 59K, it won't go off. Anybody know how to reset the service warnings? Short of ripping (edit) it out? [coffee] Thanks |
Do you have a Smarty?
smarty won't clear it. its not a service soon. at the 59k mark, the crank case filter needs to be replaced. you may have replaced it but the clearing procedure is not 3 times on the skinny pedal for the CCV filter.
https://www.dieseltruckresource.com/...e-t284851.html the actual procedure is in this thread. you will however need to return your programming back to stock and then perform the procedure. then reload your tune and you will be fine for another 60k miles |
Originally Posted by cbrahs
(Post 2975187)
https://www.dieseltruckresource.com/...e-t284851.html the actual procedure is in this thread. you will however need to return your programming back to stock and then perform the procedure. then reload your tune and you will be fine for another 60k miles I'll check out the link. Thanks Smarty? NEVER! |
Cleaning the EGR. Yeah Right. LOL I unpluged that puppy before I left the dealer when new.
OK so the proceedure is: Turn the key on hit the brake pedal twice then hit the fuel pedal twice in 10 seconds turn the key off all the way. (Removing the key fixes stuff too) Then start. I'll do that in the morning Thanks |
