Reverse lights on while braking? Hmm...
Old Dec 19, 2013 | 07:48 PM
exwrestler's Avatar
I step on the brakes and the reverse lights also come on. What's going on? How or what can be fixed.
Old Dec 19, 2013 | 11:06 PM
seafish's Avatar
Sounds like it might be a short or bad grund at the tailights between the reverse and brake bulb wiring...maybe pinched wires, but more likely water in the tailight housing casuing corrosion and/or a bad ground causing the brake bulb to find ground through the reverse bulb. Gonna have to open up the tailight housings and check the connections.
Old Dec 20, 2013 | 08:32 AM
Shorts's Avatar
I'd investigate for a short as well. Could be a chaffed wire somewhere in there. Start simple, check the obvious stuff - connections & bulbs to rule them out. Then get OCD on the wires.
Old Dec 20, 2013 | 12:11 PM
Chrisreyn's Avatar
^^what they said^^
Coolhand37
36
Aug 19, 2007 07:14 PM
Gman77
14
Mar 1, 2007 11:11 PM
jethroib
Mar 6, 2006 01:41 PM
Turbo Deeezle
Jan 20, 2005 06:46 AM
goin
Aug 7, 2003 06:33 AM
