Replaced VSS still speedo problems!!!!!
Old Jul 23, 2008 | 12:03 AM
southpawslingr1's Avatar
I posted a while back that my speedometer was doing some strange bouncing around. Sometimes shutting off for a day. It comes back on for a while then does the same thing again. The abs and brake light comes on as well. It was generally accepted I would have to change my vehicle speed sensor. Well I went ahead and ordered one and while installing my con fe I threw the new one in the pumpkin. Low and behold still the same problem!!!!!!!!!!!
Old Jul 23, 2008 | 07:22 AM
FMB's Avatar
FMB
I suppose it could be a bad VSS, even new, but I would trace the harness to see if it was damaged anywhere before I'd buy another VSS.
Back to morning refreshment. . .
Old Jul 23, 2008 | 07:42 AM
John Faughn's Avatar
Guess is only for where to start testing , test what you guess is wrong .
I have not worked with that yr , but you mentioned pumpkin , I figured that was the anti lock brake sensor , and the VSS would be in the trans or transfer case .
Did you check for codes ?
Old Jul 25, 2008 | 11:31 AM
No codes that I know of. Really starting to tick me off though.
Old Jul 26, 2008 | 03:23 PM
" that you know of " that leaves it wide open .
How do you know if you have codes or not ?
Old Jul 26, 2008 | 09:52 PM
Using the SMARTY...
Old Jul 28, 2008 | 07:53 PM
dozer12216's Avatar
The rear axle sensor is the sensor that ultimatelly drives speedometer. As you have learned the ABS lights come on also. Since you have replaced the sensor and the ABS light comes on, that indicates the problem is between sensor and ABS module. Corrosion or damaged wires most likely from sensor.
Sleigher
May 4, 2017 02:12 PM
FirstGen1991
Jun 13, 2013 08:21 PM
siebertl
Sep 28, 2011 04:33 PM
jesussaves
Jul 18, 2009 05:45 PM
jmon12
Jan 29, 2007 07:50 PM
