Removed bed, taillight wiring woes
Old Mar 31, 2013 | 07:46 PM
2tone12valve's Avatar
Hello all. I've done some searching through old threads and couldn't find anything addressing this. I pulled the bed off my truck to haul a low-clearance trailer, and have some LED brake/turn/tail lights I'm trying to use.
My issue isn't the "Lamp out" indicator, I'm aware of the resistors needed to stop this. The problem is, I've found that there are separate circuits for the turns and brakes, and upon attempting to wire them to the same circuit on the new tails, the turn does not cancel out the brake light. The brake overrides the turn and makes it not function as it should. Has anybody done something like this and found a solution, or will I have to add an additional light for a turn signal?
The other solution I've thought about is wiring resistors into the factory taillight wiring, and just tapping into the 7-way trailer plug wiring. Just trying to keep it clean, without hacking into too much factory wiring.
The truck I'm working on is an '03 Ram 3500 CTD
Old Mar 31, 2013 | 10:26 PM
BigIron70's Avatar
Cummins Guru
I think oreilly auto sells them, you just need to wire it in. Piece of cake
http://www.oreillyauto.com/site/c/de...ler+light+kits
Old Apr 1, 2013 | 05:28 PM
Seems to have done the trick on the side I managed to get done today. Thanks a lot, that was exactly what I needed.
Firstgenfanatic
Feb 18, 2009 09:54 PM
2500CTD
Aug 22, 2005 01:41 AM
Kenworth
Jul 5, 2005 11:36 PM
TXPOWER
Mar 10, 2005 04:06 PM
