Re-gear with limited slip
Hi all,
When re-gearing a truck from a 3.55 to a 4.10, does the factory limited slip need to be replaced, or will it work with the new ring and pinion? Thanks. Gman |
Dodge hasn't used 3.55's in the 3rd gens, you should have 3.73's. I am upgrading the gears in my 04.5 and according to 6 states the carrier doesn't need to be changed in order to swap to 4.10's. I hope this helps.
You should have the 3.73's. Going to the 4.10's is no problem.
