Power window engages blower motor?
Old Nov 24, 2008 | 01:57 PM
c-bass's Avatar
I recently purchased an '04 QC and noticed something strange with the power windows/blower motor.
If the passenger side switch is used to operate the window, it will work normal for 1 second and then somehow the blower motor is engaged and the window movement slows to a crawl.
Everything works fine using the driver's side controls.
Also another thing I noticed that might be related or not is the rear doors won't operate the windows with their respective swtiches but they work from the driver's controls. I figured there was something wrong with the child lockout switch at first but now I'm rethinking my theory.
Anyone experience anything like this before or can point me in the direction I should start looking for a solution?
Old Nov 24, 2008 | 02:34 PM
MikeyT's Avatar
Weird. I just noticed that my passenger side window switch is only working intermittantly, but I haven't seen any blower motor involvement. My driver's side controls also work fine.
Old Nov 24, 2008 | 08:12 PM
c-bass's Avatar
Originally Posted by st.rodder2
I had the same problem -- all windows only worked from drivers door. It was the window lock out button on the drivers door. Replaced it and all works fine. Went thru 3 switches on my 02 1500 b4 I upgraded to the 2500 CTD.
Like I said, the passenger side window will work with the passenger side switch...but it's got that little extra function associated with it, which is why I'm thinking it might not be the lock out switch.
How much did the switch set you back? I might replace it anyway if it's not too expensive.
Old Nov 25, 2008 | 06:39 PM
jivemother's Avatar
kinda same problem replaced drivers door switch everthing went to normal
Jim Lane
Apr 5, 2020 06:03 AM
90 power ram
Apr 3, 2014 08:32 PM
moparman13045
Feb 15, 2012 06:53 AM
MARF75
Jul 22, 2011 11:39 PM
Dufrain
Mar 20, 2008 07:34 AM
